BE3600 - Prometheus metrics missing some values
I’m troubleshooting some missing metrics from the BE3600.
Looks like we are missing the hostapd_stations.lua file from /usr/lib/lua/prometheus-collectors
however even the iwinfo wlan0 info command is incomplete
BE3600 env
root@GL-BE3600:~# uname -a
Linux GL-BE3600 5.4.213 #0 SMP PREEMPT Tue Aug 19 14:33:15 2025 aarch64 GNU/Linux
root@GL-BE3600:~# opkg list-installed | grep prometheus
prometheus-node-exporter-lua - 2024.06.16-2
prometheus-node-exporter-lua-hostapd_ubus_stations - 2024.06.16-2
prometheus-node-exporter-lua-hwmon - 2024.06.16-2
prometheus-node-exporter-lua-nat_traffic - 2024.06.16-2
prometheus-node-exporter-lua-netstat - 2024.06.16-2
prometheus-node-exporter-lua-openwrt - 2024.06.16-2
prometheus-node-exporter-lua-thermal - 2024.06.16-2
prometheus-node-exporter-lua-uci_dhcp_host - 2024.06.16-2
prometheus-node-exporter-lua-wifi - 2024.06.16-2
prometheus-node-exporter-lua-wifi_stations - 2024.06.16-2
MT3000 env
root@GL-MT3000:~# uname -a
Linux GL-MT3000 6.6.93 #0 SMP Mon Jun 23 20:40:36 2025 aarch64 GNU/Linux
root@GL-MT3000:~# opkg list-installed | grep prometheus
prometheus-node-exporter-lua - 2025.07.15-r1
prometheus-node-exporter-lua-hostapd_ubus_stations - 2025.07.15-r1
prometheus-node-exporter-lua-hwmon - 2025.07.15-r1
prometheus-node-exporter-lua-nat_traffic - 2025.07.15-r1
prometheus-node-exporter-lua-netstat - 2025.07.15-r1
prometheus-node-exporter-lua-openwrt - 2025.07.15-r1
prometheus-node-exporter-lua-thermal - 2025.07.15-r1
prometheus-node-exporter-lua-uci_dhcp_host - 2025.07.15-r1
prometheus-node-exporter-lua-wifi - 2025.07.15-r1
prometheus-node-exporter-lua-wifi_stations - 2025.07.15-r1
root@GL-MT3000:~#
The compare of the MT3000 and a BE3600 metrics in my lab shows that the BE3600 is missing the related wifi and hwmon i.e. the fan. in the BE3600 unit.
I have tried copying all the collector lua files from the mt3000 over to the BE3600 overwriting the stock BE3600 collector lua files, and restarted the prometheuss-node-exporter service , however that did not make any chance in the metrics displayed.
Can anyone guide me how I can get the missing metrics to display? Thank you.
