Cool! Thanks!
BE6500 VLAN and WIFI Configuration via SSH/UCI and LuCI
Previously in Reference 2, a sample of Lan based iot Vlan on BE6500 was created via SSH/UCI scripting and via LuCI GUI, without using network Bridge device. However, a Vlan bridge device is necessary for adding/binding a wifi ssid to a specific Vlan.
References
Ref.1 @bruce @will.qiu : https://forum.gl-inet.com/t/flint-3-gl-be9300-as-ap-behind-pfsense-multiple-ssids-vlan-random-bssid/66719
Ref.2
This is a follow-up descripting BE6500 wifi creation for specific Vlan, an IOT (Vlan 21) in this example, via SSH/UCI scripting and via LuCI GUI.
Environment:
· Same as those listed in Ref.2
· Plus: Create 2.4Ghz and 5Ghz wifi and bind their SSIDs to IOT (Vlan 21) network, so that wireless devices are in the same Vlan network.
Pre-condition:
· BE6500 is manufactured reset
· Basic Wan/Lan settings completed
Two approaches:
- VLAN & VLAN Based Wifi Configuration via SSH/UCI script
- VLAN & VLAN Based Wifi Configuration via LuCI GUI
Part 1 - BE6500 VLAN & Wifi Configuration via SSH/UCI script
Compared with Lan based Vlan configuration described in Ref.2, following additional steps are added:
· Bridge device (for iot) to allow binding Wifi ssid to iot Vlan
· 2.4 GHz wifi binding with iot Vlan
· 5Ghz wifi binding with iot Vlan
Wifi related UCI script was largely derived from @bruce code in Ref.1, with minor modifications.
Use SSH or PuTTY (login as root) and run following UCI script
#Create VLAN 21 (IOT)
#Setup Physical Lan Port 1 as trunk port for downstream AP/switch
#swconfig Switch 1 Port 3 = cpu
#swconfig Switch 1 Port 7 = Physical Lan Port 1
uci set network.vlan_iot='switch_vlan'
uci set network.vlan_iot.device='switch1'
uci set network.vlan_iot.vlan='21'
uci set network.vlan_iot.ports='3t 7t'
#Create sub-interface/device for VLAN 21
uci set network.eth1_21='device'
uci set network.eth1_21.name='eth1.21'
uci set network.eth1_21.type='8021q'
uci set network.eth1_21.ifname='eth1'
uci set network.eth1_21.vid='21'
# Add Bridge
uci set network.br_iot=device
uci set network.br_iot.type='bridge'
uci set network.br_iot.name='br-iot'
uci add_list network.br_iot.ports='eth1.21'
#Create the IOT interface
uci set network.iot='interface'
uci set network.iot.device='br-iot'
uci set network.iot.proto='static'
uci set network.iot.ipaddr='192.168.21.1'
uci set network.iot.netmask='255.255.255.0'
#Enable DHCP for IOT
uci set dhcp.iot='dhcp'
uci set dhcp.iot.interface='iot'
uci set dhcp.iot.start='100'
uci set dhcp.iot.limit='150'
uci set dhcp.iot.leasetime='12h'
#Create the IOT firewall zone
uci add firewall zone
uci set firewall.@zone[-1].name='iot'
uci set firewall.@zone[-1].network='iot'
uci set firewall.@zone[-1].input='REJECT'
uci set firewall.@zone[-1].output='ACCEPT'
uci set firewall.@zone[-1].forward='REJECT'
uci set firewall.@zone[-1].masq='1'
uci set firewall.@zone[-1].mtu_fix='1'
#Allow IOT to access WAN
uci add firewall forwarding
uci set firewall.@forwarding[-1].src='iot'
uci set firewall.@forwarding[-1].dest='wan'
#Allow DHCP & DNS on IOT
uci add firewall rule
uci set firewall.@rule[-1].name='Allow-IOT-DHCP'
uci set firewall.@rule[-1].src='iot'
uci set firewall.@rule[-1].proto='udp'
uci set firewall.@rule[-1].dest_port='67-68'
uci set firewall.@rule[-1].target='ACCEPT'
uci set firewall.@rule[-1].name='Allow-IOT-DNS'
uci set firewall.@rule[-1].proto='tcp udp'
uci set firewall.@rule[-1].dest_port='53'
#Add WiFi SSID Radio - 5G
uci set wireless.wifi5g1=wifi-iface
uci set wireless.wifi5g1.device='wifi1'
uci set wireless.wifi5g1.network='iot'
uci set wireless.wifi5g1.mode='ap'
uci set wireless.wifi5g1.ssid='GL Router-iot-5G'
uci set wireless.wifi5g1.encryption='psk2+ccmp'
uci set wireless.wifi5g1.key='goodlife'
uci set wireless.wifi2g2.wds='1'
uci set wireless.wifi5g1.isolate='0'
uci set wireless.wifi5g1.hidden='0'
uci set wireless.wifi5g1.ieee80211k='1'
uci set wireless.wifi5g1.bss_transition='1'
uci set wireless.wifi5g1.sae='0'
uci set wireless.wifi5g1.disabled='0'
#Add WiFi SSID Radio - 2.4G
uci set wireless.wifi2g1=wifi-iface
uci set wireless.wifi2g1.device='wifi0'
uci set wireless.wifi2g1.network='iot'
uci set wireless.wifi2g1.mode='ap'
uci set wireless.wifi2g1.ssid='GL Router-iot-2.4G'
uci set wireless.wifi2g1.encryption='psk2+ccmp'
uci set wireless.wifi2g1.key='goodlife'
uci set wireless.wifi2g1.isolate='0'
uci set wireless.wifi2g1.hidden='0'
uci set wireless.wifi2g1.ieee80211k='1'
uci set wireless.wifi2g1.bss_transition='1'
uci set wireless.wifi2g1.sae='0'
uci set wireless.wifi2g1.disabled='0'
#Commit and Reboot
uci commit
reboot
Newly added 2.4Ghz/5Ghz Wifi are activated and configurations are present in both
· GL-BE6500 Admin Panel / WIRELESS, and
· LuCY->Network->Wireless
Part 2: BE6500 VLAN & Wifi Configuration via LuCI GUI
2.1 Setup VLAN 21 network
As mentioned in Ref.2, VLAN 21 network setup via LuCI GUI has following 6 steps:
Network bridge device was optional (not necessary) for Lan based Vlan, and the network bridge was not created from the above steps. However, to add/bind wifi into a Vlan network, a network bridge device is required.
To add a Vlan based Bridge device, Step 3 listed above needs to be revised as follow:
Step 3 Create VLAN 21 (IOT) Bridge and Interface
Step 3.1 Create IOT Bridge Device: br-iot
· LuCI->Network->Interfaces->devices
· Click “Add device Configuration”, and select/input info as below, then click Save
Now Vlan21 bridge device “br-iot” is created
Step 3.2 Create VLAN 21 (IOT) Interface
· LuCI->Network->Interfaces->Interfaces
· Go to bottom of the page and Click “Add new interface”
Protocol: Static address
Device: select “br-iot”
· Click “Create interface”
· Add IPv4 address/netmask: 192.168.21.1/255.255.255.
Do not Save.
This is the end of revised Step 3, Continue rest of steps to complete the Vlan 21 network configuration.
2.2 Setup 2.4Ghz/5Ghz wifi for VLAN 21
Steps for adding both 2.4Ghz wifi and 5Ghz wifi into Vlan 21 network are identical.
Step 2.1 Choose a new 2.4Ghz or 5Ghz wifi to create
· LuCI->Network->Wireless
To create a 2.4Ghz wifi, go to “wifi0” line and click Add
To create a 5Ghz wifi, go to “wifi1” line and click Add
Step 2.2 Create 2.4Ghz Wifi
· Select from dropdown. Enter a proper SSID name in ESSID field
· Do not save
· Go to “Wireless Security” tab
· Select Encryption and Cipher from dropdown
· Enter a wifi password in Key field.
· Click “Save”
· Click Save & Apply for 2.4Ghz wifi configuration.
Step 2.3 Create 5Ghz Wifi
Repeat the same step as Step 2.2 for 5Ghz Wifi creation - consider using a different 5G ssid name
Step 2.4 Reboot Router
· LuCI->System->Reboot
Now 2.4Ghz and 5Ghz wifi SSIDs are activated. Wireless devices connected to them are sharing the same Vlan 21 network. Specific Wifi configurations are present in both
Hello, forum. I got the router back. Time to start playing with it again.
This is the default configuration.
The appearance of switch0 in LuCI is a misidentification by the interface. Please note that this represents the internal packet processing/switching engine within the SoC, rather than a discrete external switch controller.
As we are not responsible for the maintenance of LuCI, please disregard the switch0.
Hello, Bruce. I understand the mis-identification part, but at least that should be explained in the router documentation. Also, the ports being mislabel 1=4 and 4=1 not ideal.
I see the router has been upgraded to version 4.9.0 to me is quite interesting you guys are not using DSA for advance configurations.
Coming back to this topic.
There is something that does not adds up. Once the device has been created, and has been connected to the proper interface, provided the firewall and static ip are configure properly. In my unit firmware version 4.9.0 the SW-config is not doing what I needed to do.
To provide IP’s on a single Ethernet port for that VLan.
For a normal client connected directly to one dedicated Ethernet port, configure that port as a VLAN 21 access port, not a tagged trunk:
- On Switch 1, keep the CPU port tagged for VLAN 21.
- Set the selected physical LAN port untagged for VLAN 21 and off for VLAN 1. A port must not be untagged in both VLANs.
- Keep the interface attached to
eth1.21(or its bridge), with DHCP enabled. - Double-check the reversed LuCI port mapping: the physical port number may not match the displayed LAN number.
After applying, connect an ordinary untagged client and renew its lease. If it receives no address, temporarily assign it 192.168.21.2/24 and ping 192.168.21.1. A successful ping would show that switching/VLAN membership works and narrow the problem to DHCP or firewall configuration; a failed ping would point back to the switch port membership or port mapping.
