Beryl 7 drops DSCP 46 (EF) packages when dscp_pri_map_enable='1'
Greetings,
Recently while connecting to other devices on my local network, I noticed that suddenly I was unable to connect to SSH networks, not to the router, nor to other devices.
While debugging, turns out every package that was being marked as EF, and were being dropped for some reason. I even had to manually set IPQoS to none in my ssh config for ssh to not be dropped.
Setting dscp_pri_map_enable to 0 and restarting the router fixes the issue. I assume this is a bug, but please do let me know if this is expected behavior.
