Beryl 7 (GL-MT3600BE) firmware 4.9.0: WDS repeater drops 5 GHz uplink on group key rekey (reason 16), then takes ~2.5 min to recover
Setup
  • Device: GL.iNet Beryl 7 (GL-MT3600BE), firmware 4.9.0
  • Mode: Repeater with WDS, 5 GHz uplink (apclii0 is bridged into LAN; LAN gets its IP from the main router via DHCP)
  • Uplink: SSID HomeNet-5G, channel 36, WPA3-SAE, MLO disabled on the client (ApcliMloDisable = 1)
  • Main router: Banana Pi R4, OpenWrt-based hostapd on MediaTek
  • Frequency: every group rekey
MAC addresses and SSID are anonymized. [REPEATER] is the GL.iNet's apclii0 and [MAIN-AP] is the main router's BSSID; each is the same device in both logs.
Problem 1: Uplink is dropped when the main router rotates its group key
When the main router does a group key rekey, the GL.iNet never answers the group key handshake. After 4 tries the main router deauthenticates it with reason 16 (group key handshake timeout). Other clients on the same SSID complete the same rekey without trouble.
Main router log:
[2:47:46 PM] hostapd: phy0.1-ap0: STA [CLIENT-A] WPA: group key handshake completed (RSN)
[2:47:46 PM] hostapd: phy0.1-ap0: STA [CLIENT-B] WPA: group key handshake completed (RSN)
[2:47:49 PM] hostapd: phy0.1-ap0: STA [REPEATER] WPA: group key handshake failed (RSN) after 4 tries
[2:47:49 PM] hostapd: phy0.1-ap0: AP-STA-DISCONNECTED [REPEATER]
[2:47:49 PM] hostapd: mtk: update disconnect counter: type=DEAUTH, from_sta=0, addr=[REPEATER], reason=16
[2:47:54 PM] hostapd: phy0.1-ap0: STA [REPEATER] IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
[2:47:54 PM] hostapd: handle_assoc_cb: STA [REPEATER] not found
[2:50:06 PM] hostapd: phy0.1-ap0: AP-STA-CONNECTED [REPEATER] auth_alg=sae
The GL.iNet log has nothing about the rekey. The first entry is the disconnect itself:
Fri Oct  9 14:47:49 2026 daemon.err gl-repeater[14912]: (repeater.lua:663) disconnected from HomeNet-5G [MAIN-AP]
Problem 2: Recovery takes ~2.5 minutes and drops every client on the GL.iNet
The uplink loss itself is brief, but gl-repeater's recovery makes it much worse:
  1. It restarts the whole network: both radios, all local SSIDs, both Ethernet ports, even loopback. Every wired and wireless client on the GL.iNet loses connectivity.
  2. The 5 GHz rescan times out, costing ~40 s:
Fri Oct  9 14:49:11 2026 daemon.err gl-repeater[14912]: (repeater-mtkwifi7.lua:478) rai15 : wait scan done fail: timeout
  1. The next scan finds the main router but skips it because the BSSID is still marked disabled, adding another 30 s:
Fri Oct  9 14:49:21 2026 daemon.info gl-repeater[14912]: (repeater.lua:1204) switch to HomeNet-5G
Fri Oct  9 14:49:21 2026 daemon.info gl-repeater[14912]: (repeater.lua: 62) skip disabled bss [MAIN-AP]
Fri Oct  9 14:49:21 2026 daemon.info gl-repeater[14912]: (repeater.lua:1213) not found matched bss for HomeNet-5G
Fri Oct  9 14:49:21 2026 daemon.info gl-repeater[14912]: (repeater.lua:1706) switch in 30 seconds...
  1. It finally reconnects at 14:49:58 and gets a DHCP lease at 14:50:08. Total outage: about 2 min 20 s.
Questions
  • Is the group key rekey failure a known issue with the repeater client (WPA3-SAE, WDS mode)? Is it fixed in a newer firmware?
  • Can the recovery be made less disruptive? For example, not restarting the entire network, or not blocking the only saved BSSID?
Raising wpa_group_rekey on the main router would make the drops rarer, but it doesn't fix the underlying problem. I can provide full logs from both devices if needed.
Adding a second report. Same model and firmware, same rekey failure, but a slightly different symptom that might be useful to R&D -- in my case the upstream AP doesn't deauth the Beryl, so there's no disconnect and no recovery. The link just goes silently dead and stays that way until I toggle the repeater off/on.
Setup
  • GL-MT3600BE (Beryl 7), firmware 4.9.0 (kernel 5.4.281, build dated Jul 2 2026)
  • Repeater mode (not WDS), 5 GHz uplink to a shared multi-tenant office network, WPA2-PSK, channel 149
  • Laptop on the Beryl's LAN port
  • Scheduled reboot at 3:00 AM daily
  • Other tenants on the same upstream SSID don't see this
Symptom
Every day at ~11:00 AM the Beryl loses internet. Admin panel still works, the repeater still shows connected to the upstream SSID, WAN tracker never fails over. Disable repeater -> enable -> reconnect fixes it in ~30 seconds. Fine the rest of the day.
Key detail: it's not 11 AM, it's 8 hours after association. I reboot at 3:00, the repeater associates at 3:01:34, and the failure hits at 11:02:06. So the upstream AP (that I don’t have any control over) is almost certainly doing a pairwise/session rekey on an 8-hour timer, same as the group rekey in the OP.
Logs
Association after the 3 AM reboot:
Wed Oct 14 03:01:34 2026 daemon.notice netifd: Network device 'apclii0' link is up
Wed Oct 14 03:01:34 2026 daemon.info gl-repeater[19484]: (repeater.lua:639) connected to [UPSTREAM-SSID] 98:52:xx:xx:xx:4c
Wed Oct 14 03:01:38 2026 daemon.notice netifd: wwan (22070): udhcpc: lease of 192.168.0.207 obtained, lease time 86400
Wed Oct 14 03:01:38 2026 daemon.notice netifd: Interface 'wwan' is now up
Nothing at all in the log for the next 8 hours. Then at 8h 0m 32s after association, the driver dumps the WTBL entry for the upstream AP and starts failing every inbound frame on wcid 1:
Wed Oct 14 11:02:06 2026 kern.warn kernel: [28908.780368] Dump WTBL info of WLAN_IDX:1
Wed Oct 14 11:02:07 2026 kern.err kernel: [28909.695086] 7993@ERROR.RX,apclii0,header_packet_process() 6549: CheckRxError, wcid(1)!
        SN=1253  PN=0x10f942  BSS_IDX=1
Wed Oct 14 11:02:08 2026 kern.err kernel: [28910.792540] 7993@ERROR.RX,rai15,header_packet_process() 6549: CheckRxError, wcid(1)!
        SN=1254  PN=0x10f943
Wed Oct 14 11:02:09 2026 kern.err kernel: [28911.890210] 7993@ERROR.RX,rai15,header_packet_process() 6549: CheckRxError, wcid(1)!
        SN=1255  PN=0x10f944
Then ~200 more CheckRxError, wcid(1) lines on rai15 within about one second, with two firmware command timeouts in the middle of it:
Wed Oct 14 11:02:09 2026 kern.err kernel: [28912.310383] WiFi@ERROR.FW,UniCmdResultToRsp() 52: id=0x22,eid=0x0 cmd timeout
Wed Oct 14 11:02:09 2026 kern.err kernel: [28912.321256] 7993@ERROR.HIF,ra15,hwifi_mcu_tx() 1557: send cmd fail! ret -110
Wed Oct 14 11:02:14 2026 kern.err kernel: [28917.426331] WiFi@ERROR.FW,UniCmdResultToRsp() 52: id=0x2b,eid=0x0 cmd timeout
Wed Oct 14 11:02:14 2026 kern.err kernel: [28917.433490] 7993@ERROR.HIF,rai2,hwifi_mcu_tx() 1557: send cmd fail! ret -110
And by 11:02:11 the AP's packet counter has restarted from 1 -- i.e. the AP is now sending with a new key and the Beryl is still holding the old one:
Wed Oct 14 11:02:11 2026 kern.err kernel: [28913.xxxxxx] 7993@ERROR.RX,rai15,header_packet_process() 6549: CheckRxError, wcid(1)!
        SN=1458  PN=0x1  Key_idx=0  BSS_IDX=1
Wed Oct 14 11:02:11 2026 kern.err kernel: [28914.xxxxxx] 7993@ERROR.RX,rai15,header_packet_process() 6549: CheckRxError, wcid(1)!
        SN=1459  PN=0x2  Key_idx=0  BSS_IDX=1
Like the OP, there's zero wpa_supplicant / gl-repeater output about the rekey itself. No disconnect, no "disconnected from", nothing from kmwan. From the Beryl's point of view the WAN is fine. 40 seconds later that's me logging in and toggling it:
Wed Oct 14 11:02:46 2026 daemon.info eco[3341]: (gl-ngx-session:659) new websocket proxy connection
Wed Oct 14 11:02:47 2026 kern.warn kernel: [28950.425023] kmwan: wwan restore detect.
Wed Oct 14 11:02:48 2026 daemon.info gl-repeater[19484]: (repeater.lua:1599) disabled by user
Wed Oct 14 11:03:11 2026 daemon.info gl-repeater[19484]: (repeater.lua:639) connected to [UPSTREAM-SSID] 98:52:xx:xx:xx:4c
Wed Oct 14 11:03:11 2026 daemon.notice netifd: wwan (31238): udhcpc: lease of 192.168.0.207 obtained, lease time 86400
What I think is going on
Upstream AP rekeys 8h after association. The Beryl's MT7993 firmware either never completes the handshake or fails to install the new key (the cmd timeout / ret -110 right at that moment looks like the key-install command failing). After that every frame from the AP fails CheckRxError. In the OP's case the AP gives up and deauths (reason 16), which at least triggers gl-repeater's recovery. In my case the AP keeps the association up, so nothing on the Beryl ever notices and it stays broken indefinitely.
A couple of asks for the GL.iNet team:
  • Is the repeater client's rekey handling (pairwise and group) a known issue on the MT7993 driver in 4.9.0? Is there a fix in the pulled 4.9.1 or a snapshot?
  • Separately, gl-repeater / kmwan should probably treat "associated but 0 successful RX for N seconds" as a dead link and reconnect. The ping tracker is configured (1.1.1.1 / 8.8.8.8 / OpenDNS) but it never flagged anything here.
Happy to share the full logread export via GoodCloud or DM.
Thank you for sharing your detailed logs and observations. We have forwarded the reported Group Key Rekey handshake failure and the Repeater connectivity and recovery issues to our team for further investigation.
We are continuing to investigate these issues with the relevant team. At this stage, we don't have a confirmed firmware release or timeline to share.
Thank you for your patience and understanding.
