Model: GL-MT3600BE (Beryl 7)
Firmware: 4.9.0 (latest stable, automatic updates / Mechanic Check on)
Tailscale: bundled 1.92.5
Use case: always-on Tailscale with Advertise LAN Subnets for 192.168.30.0/24 (approved in admin console). Key expiry disabled. Not using Tailscale SSH or exit node as the primary setup.
Issue:
About every few days, Tailscale on the Beryl stops connecting to the tailnet while the router itself stays fully up. LAN clients keep working locally. From other machines on the tailnet the node shows offline / last seen hours or days ago, and Tailscale ping fails. A Tailscale off/on toggle in the GL admin panel (or a full router reboot) brings it back immediately. This has happened roughly 3–4 times over the past couple of weeks (including after an overnight hang that broke remote access to other sites via the advertised subnet).
This matches the known gap that 4.9.0 still ships Tailscale 1.92.5 while upstream has moved well past that. Is there a planned firmware that bumps Tailscale on the MT3600BE, or a supported way to run a newer Tailscale binary without breaking the Applications panel?
Happy to provide logs or reproduce steps if useful.
Thank you for the detailed report.
To help us understand what happens when Tailscale disconnects, could you please collect the following information when the issue occurs again, before toggling Tailscale or rebooting the router?
- When this happens again, connect to the router over SSH from the local network and run these commands:
uptime
free -m
grep -E 'MemAvailable|MemFree|Cached|Slab' /proc/meminfo
pidof tailscaled
for p in $(pidof tailscaled); do
grep -E 'Name|State|VmRSS|VmHWM|Threads' /proc/$p/status
done
dmesg | grep -iE 'out of memory|oom|killed process'
tailscale status
- Please also export the router’s system logs and send both the command output and logs to us via private message.
Thank you for your patience and support.
How to send private messages:
Hi charles2, quick update: the Beryl 7 (GL-MT3600BE, firmware 4.9.0, Tailscale 1.92.5) hung again this morning, Nov 6.
Timeline (US Eastern):
- 8:24 AM: healthy, Tailscale direct connection.
- ~9:32 AM: dropped off Tailscale. Wi-Fi clients on the LAN lost connectivity at the same time.
- 9:49 AM: the GL.iNet app still reached the router through GoodCloud. System Overview showed CPU load 16.91 and memory 90.9% (I'd seen it at 100% a few minutes earlier). Screenshot attached. WAN IP was unchanged.
- ~9:54 AM: the router was power cycled on site.
- 9:58 AM: back online, Tailscale direct again.
Unfortunately it was power cycled before I could run the SSH capture you asked for, so I don't have the meminfo, tailscaled status or dmesg output this time. That also cleared the system log.
Worth noting: this happened after the Oct 24 tuning (Tailscale memory cap, auto-restart, several services disabled). So the tuning reduced how often it happens but didn't stop it, and this time the whole router bogged down, not just Tailscale.
I'll run the full capture before touching anything next time. Is there a way to keep the system log across reboots, or anything else you'd like set up ahead of time?
Thank you for the update and the detailed timeline.
Please run the following commands over SSH to preserve logs across reboots and record memory usage every minute.
mkdir -p /root/ts-debug
uci set system.@system[0].log_file='/root/ts-debug/system.log'
uci set system.@system[0].log_size='1024'
uci set system.@system[0].log_buffer_size='64'
uci commit system
/etc/init.d/log restart
cat > /root/ts-debug/memory-watch.sh <<'EOF'
#!/bin/sh
echo "=== Memory snapshot ==="
uptime
grep -E '^(MemTotal|MemAvailable|MemFree|Cached|Slab|SUnreclaim|Shmem|SwapFree):' /proc/meminfo
pids="$(pidof tailscaled)"
echo "tailscaled PID: ${pids:-none}"
for p in $pids; do
grep -E '^(Name|State|VmRSS|VmHWM|Threads):' /proc/$p/status
done
} 2>&1 | logger -t memwatch
EOF
touch /etc/crontabs/root
grep -qF '/root/ts-debug/memory-watch.sh' /etc/crontabs/root ||
echo '* * * * * /bin/sh /root/ts-debug/memory-watch.sh' >> /etc/crontabs/root
/etc/init.d/cron enable
/etc/init.d/cron restart
sleep 2
sync
grep memwatch /root/ts-debug/system.log | tail -n 20
The logs will be saved to the router’s internal storage and rotated automatically to limit their size.
When the issue occurs again, please download the following files and send them to us via private message.
/root/ts-debug/system.log.old
You can use WinSCP with the SCP protocol to download them, including after a reboot; if only one file is present, please send that file.
Thank you for your patience and help.
