I'm using a Beryl 7 (GL-MT3600BE) as my main home router behind a FritzBox. Firmware: 4.9.0 Release
Setup:
- Fire TV Cube (3rd Gen) + 2x Echo Studio + Echo Sub in an Alexa Home Theater group
- Beryl 7: WireGuard client (VPN), Encrypted DNS (Control D, DoT)
- 5 GHz: channel 36 fixed, 80 MHz, WPA2/WPA3 mixed
- 2.4 GHz: 20 MHz, WPA2-PSK, randomized BSSID off
How Alexa Home Theater works: the Echos connect to a Wi-Fi network hosted by the Cube itself (SoftAP), and the Cube forwards their traffic through its own uplink to the router.
Problem:
- Cube connected to the Beryl 7's 5 GHz Wi-Fi: the Echos are online as long as they are directly connected to the Beryl. As soon as they switch to the Cube's SoftAP for the Home Theater, they lose all connectivity (no DNS, no cloud). Home Theater setup fails with "Fire TV could not connect to the Echo devices".
- Cube connected via Ethernet to a Beryl 7 LAN port (Wi-Fi still on for the SoftAP): Home Theater sets up and works immediately, with VPN and Control D active.
- With my previous router, the same setup worked with the Cube on Wi-Fi.
Already tested without success:
- VPN disconnected, non-VPN traffic allowed, plain Google DNS (8.8.8.8) – same result
- Different 5 GHz channels (non-DFS), different Wi-Fi modes, WPA2-only
- Wi-Fi 7 (be) mode cannot be disabled on 5 GHz
So the issue only affects traffic that the Cube forwards from its SoftAP clients while the Cube itself is a Wi-Fi client of the Beryl 7. The Cube's own traffic over Wi-Fi works fine.
Questions:
1. Is this a known issue with the MT3600BE Wi-Fi driver?
2. Are there settings (AP isolation, multicast/IGMP, proxy ARP, MLO etc.) I can change on 5 GHz to test this?
3. Is there a newer or beta firmware that addresses this?
Happy to provide logs if needed.
Thanks!
