Beryl 7 stuck on reset / cannot access admin
I have a GL.iNet Beryl 7 and I am currently unable to properly access or configure it.
The device powers on normally and the LED is blinking (blue/teal light), and the Wi-Fi networks appear (GLMT3600BE-bb1 and GLMT3600BE-bb1-5G). However, I have serious issues:
  • I can connect to the Wi-Fi but I have no stable internet access when not properly configured
  • I can open 192.168.8.1, but it asks for admin password
  • The “Forgot password” option appears, but it does not resolve the issue
  • Factory reset has been attempted multiple times (holding reset button for 10–20 seconds), but the device does not properly return to initial setup mode
  • After reset attempts, the device still behaves as if previous configuration remains or recovery does not complete correctly
  • The LED continues blinking and the setup flow does not fully restart cleanly
At one point, when WAN/Ethernet was connected, the device did show internet (“online”), but I still cannot properly regain full admin control or clean setup access.
I need help to:
  • fully restore factory firmware state
  • or perform a recovery / firmware reinstallation method
  • and regain access to admin interface normally
Please advise the correct recovery procedure for this situation.
Thank you.
MANASSIS YIANNIS
KERAME AGIOY BASILEIOY 74053 RETHYMNO CRETE GREECE
Please try to use the Uboot restore process to fully wipe your router: What should I do if my router is bricked - GL.iNet Router Docs 4
