Hi I’m having problems connecting my D-link DWM222 to my beryl, I can not configure it and sometimes it shows up as tethering.
If it shows as tethering you can just use as tethering. It is how the modem works.
Ahh ok. But it doesn’t seem to have a connection. I can’t get online with it.
What happened when you set up as tethering?
Is there any settings in the dlink dongle to set up as hostless?
I first set it up on my Mac, put in the pin and removed the pin lock, checked if it had a connection witch it had. Then put it in my Beryl. Sometimes it came up as a modem and I could auto set it up or manual. But on manual there was some fields I didn’t understand. And some of the drop downs had no choice. And sometimes it just came up as tethering.
I suggest you check dlink dongle settings and set it up in tethering. From your description it somes time appears as modem and sometime appears a tethering. It is very strange.
You need to post screenshot.
Got it to work, just had to turn of my DNS settings. Connect, then it worked. And then I could turn on DNS settings again.
