Can someone point me in the right direction to share files on the above router. I have inserted a 512gb micro SD card in to the slot but cannot see the option to share the files externally?
Thank you.
Thank you.
Please refer to:
Thank you for your reply, but there is no Network storage in the applications section of my router?
Could you please clarify your device model and current firmware version?
If possible, please include the following screenshots so we can better understand the situation.
Hello Will.qiu.
The router is a GL-MT1300 (Beryl)
Firmware version 4.3.25
Unfortunately, this model does not support Network Storage.
You can find the list of supported models in the link provided earlier.
However, if you only require basic file access, you can install and configure lightweight services via SSH, such as WebDAV.
OpenWrt provides a suitable guide here:
Please note that the device’s hardware resources will limit performance and stability, so this approach is recommended only for light use cases.
But it’s got an Micro SD slot and a USB slot, what are these for?
Perhaps I didn’t explain it clearly before.
After upgrading to firmware v4, the MT1300 no longer has enough storage space to include Network Storage, so this feature is not built into the MT1300.
We recommend considering the following:
Download link:
Downgrade guide:
