I initially added my WG configurations from a zip file and all is good.
Then I changed some parameters in the UI, specifically I had to lower the MTU because I am using a 4g+ connection and Wireguard doesn’t play well with a MTU of 1420.
From this point, If I try to upload more configurations, the UI goes crazy.
For example, trying to upload this file
has this result:
even if I have not touched the MTU field… Seems that is mixing the settings from my existing configurations…
Moreover, yesterday I tried to add configurations to the existing ones from another zip file instead of a single txt file and the WG section in the UI disappeared, leaving a completely blank page on “Dashboard VPN” section. A reboot did not help, I had to reset the firmware…
