Beryl AX Cannot Discover External Samsung 8TB SSD in Caddy
I recently purchased a Beryl AX and alongside an 8TB Samsung EVO 870 SSD in a UGREEN caddy. This combination of SSD and Caddy has been formatted as NTFS and is discoverable by my Dell XPS17 without and issue. I also have a 5TB Lacie external portable drive that I have been using. THe Beryl AX has no problem in discovering the Lacie drive and I can set up a network share easily (as per GLi-net instructions). The Beryl AX cannot/will not discover the external SSD and Caddy! Why? I have checked all appropriate plug-ins have been installed and tried rebooting Beryl AX before connecting the SSD+Caddy drive. What am I doing wrong (if anything). I am going to try an external power supply to the SSD but I don't think this is the problem as the I'm sure the Lacie drive (non-SSD) would require more power than the SSD+Caddy and the Beryl has no problem with this drive.
Please connect the HDD to your router and run dmesg | tail -n 20 using SSH after it.
Post the output here.
Here's the output
login as: root
root@192.168.8.1's password:
BusyBox v1.33.2 (2024-06-28 08:20:53 UTC) built-in shell (ash)
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
_____|| |
||||___||| |____|
| W I R E L E S S F R E E D O M
OpenWrt 21.02-SNAPSHOT, r15812+899-46b6ee7ffc
root@GL-MT3000:~# dmesg | tail -n 20
[ 228.245540] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 3, ContTxFailCnt300ms = 3
[ 228.254932] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 9, free_token_cnt = 2295
[ 228.608687] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 8, ContTxFailCnt300ms = 5
[ 228.618087] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 6, free_token_cnt = 2298
[ 228.912676] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 11, ContTxFailCnt300ms = 3
[ 228.922158] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 7, free_token_cnt = 2297
[ 229.392846] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 17, ContTxFailCnt300ms = 6
[ 229.402324] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 7, free_token_cnt = 2297
[ 229.813385] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 24, ContTxFailCnt300ms = 7
[ 229.822865] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 3, free_token_cnt = 2301
[ 230.163890] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 27, ContTxFailCnt300ms = 3
[ 230.173373] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 7, free_token_cnt = 2297
[ 230.553908] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 32, ContTxFailCnt300ms = 5
[ 230.563387] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 3, free_token_cnt = 2301
[ 232.269335] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
[ 232.278729] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 2, free_token_cnt = 2302
[ 232.980995] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 3, ContTxFailCnt300ms = 2
[ 232.990387] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 1, free_token_cnt = 2303
[ 389.381649] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
[ 389.391040] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by curren t wcid = 1, free_token_cnt = 2303
root@GL-MT3000:~#
I hope you can help with this.
There is no entry for this device, which might be because of those nasty debug messages.
Can you please try dmesg | grep usb -C 5 instead?
Fore some reason the editor is telling me I can't paste mote than 2 links in a post. What is going on??
Maybe some of those entries look like URLs.
A screenshot is fine as well.
Here you go (copied text into text editor and removed links)
login as: root
_____|| |
||||___||| |____|
root@GL-MT3000:~#
root@GL-MT3000:~# dmesg | grep usb -C 5
[ 3.382274] create warp_ctrl ok!!!
[ 3.385711] wed_get_slot_map(): assign slot_id:0 for entry: 0!
[ 3.391549] wed_get_slot_map(): assign slot_id:1 for entry: 1!
[ 3.398627] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 3.413940] init: - preinit -
[ 3.524384] usb 2-1: new SuperSpeed Gen 1x2 USB device number 2 using xhci-mtk
[ 3.560014] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 3.589191] scsi host0: usb-storage 2-1:1.0
[ 3.787811] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 4.613498] scsi 0:0:0:0: Direct-Access ASMT 2235 0 PQ: 0 ANSI: 6
[ 4.623026] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.880066] mount_root: loading kmods from internal overlay
[ 7.896885] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 9.842156] Mirror/redirect action on
[ 9.851720] u32 classifier
[ 9.854490] input device check on
[ 9.858165] Actions configured
[ 9.868093] fuse: init (API version 7.31)
[ 9.877622] usbcore: registered new interface driver cdc_acm
[ 9.883332] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 9.892502] usbcore: registered new interface driver cdc_wdm
[ 9.902488] usbcore: registered new interface driver ipheth
[ 10.965707] mt_wifi: module license 'Proprietary' taints kernel.
[ 10.971743] Disabling lock debugging due to kernel taint
[ 11.020721] conninfra@(conninfra_pwr_on:120) [conninfra_pwr_on] drv=[3]
[ 11.028292] conninfra@(_consys_polling_chipid_int:306) Read CONNSYS HW IP version successfully! (0x02090000)
[ 11.046178] Adie Type: 0x7976
[ 11.205473] -->mtfwd_init(ver:2.0)
[ 11.205543] <--
[ 11.209618] mtk_warp_proxy: module uses symbols from proprietary module mt_wifi, inheriting taint.
[ 11.221988] -->mtqos_init(), mtqos ver:1.0
[ 11.222031] <--
[ 11.239968] usbcore: registered new interface driver ums-alauda
[ 11.246630] usbcore: registered new interface driver ums-cypress
[ 11.275487] usbcore: registered new interface driver ums-datafab
[ 11.282148] usbcore: registered new interface driver ums-freecom
[ 11.289333] usbcore: registered new interface driver ums-isd200
[ 11.296819] usbcore: registered new interface driver ums-jumpshot
[ 11.303752] usbcore: registered new interface driver ums-karma
[ 11.311784] usbcore: registered new interface driver ums-sddr09
[ 11.318508] usbcore: registered new interface driver ums-sddr55
[ 11.325707] usbcore: registered new interface driver ums-usbat
[ 11.336708] usbcore: registered new interface driver usbserial_generic
[ 11.343312] usbserial: USB Serial support registered for generic
[ 11.367722] xt_time: kernel timezone is -0000
[ 11.373084] usbcore: registered new interface driver cdc_ether
[ 11.380455] usbcore: registered new interface driver cdc_ncm
[ 11.387918] usbcore: registered new interface driver huawei_cdc_ncm
[ 11.399744] PPP generic driver version 2.4.2
[ 11.405999] NET: Registered protocol family 24
[ 11.411901] usbcore: registered new interface driver qmi_wwan
[ 11.418930] usbcore: registered new interface driver rndis_host
[ 11.428328] wireguard: WireGuard 1.0.0 loaded. See wireguard for information.
[ 11.436234] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld. All Rights Reserved.
[ 11.448186] usbcore: registered new interface driver option
[ 11.453871] usbserial: USB Serial support registered for GSM modem (1-port)
[ 11.462888] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 12.873098] Enable hnat guest interface
[ 12.877044] Disable hnat ipv6
[ 14.798059] kmwan: sensitivity and mode are set.
[ 15.439480] MediaTek MT7981 PHY mdio-bus:00: TX-VCM SW cal result: 0x1
root@GL-MT3000:~#
Is there any update on this? I have since tried the SSD+Caddy with and external power supply with no effect, definitely something wrong with the Beryl AX router.
Well, thanks for your initial reply but I realised I needed to sort this one out myself so, I have now (finally) discovered the solution after trying a number of disks and routers the solution was actually quite simple - the new router did not have any of the SMB4 plug-ins installed. Once I installed all of these plug-ins and re-booted the Beryl AND a new Spitz AX and BOTH routers now recognise my custom 8TB SSD plus UGREEN case combo plus a Samsung EVO 8TB SSD deviceand the media partitions on which my files are stored. NO separate power was needed for either SSD disk. Anyway........... just thought I'd provide an update.
