Beryl AX Configuration
Is this a supported (reliably) network configuration on Beryl AX with 4.8.1?
  • Three isolated Wi-Fi networks (Home, Guest, VPN).
  • VPN works only on VPN WiFi network
  • Networks do not see each other.
If so, can this setup be configured in the GL admin panel? Luci? SSH?
Thanks!
No input?
@bruce @lun etc…
:frowning:
For this requirement:
  1. Home and Guest Wi-Fi Newtok are built-in features.
  2. For VPN networks, please SSH into the router and run the following command to create:
# Add new bridge device for VPN networks
uci add network device # =cfg1b0f15
uci set network.@device[-1].type='bridge'
uci set network.@device[-1].name='br-vpn'
uci set network.@device[-1].bridge_empty='1'
# Configure a static address for the VPN network bridge device
uci set network.VPN=interface
uci set network.VPN.proto='static'
uci set network.VPN.device='br-vpn'
uci set network.VPN.ipaddr='192.168.11.1'
uci set network.VPN.netmask='255.255.255.0'
# Configure DHCP for the VPN interface
uci set dhcp.VPN=dhcp
uci set dhcp.VPN.interface='VPN'
uci set dhcp.VPN.start='100'
uci set dhcp.VPN.limit='150'
uci set dhcp.VPN.leasetime='12h'
uci set dhcp.VPN.dhcpv6='disabled'
uci set dhcp.VPN.ra='disabled'
# Add new VPN firewall zone
uci add firewall zone # =cfg24dc81
uci set firewall.@zone[-1].name='vpn'
uci set firewall.@zone[-1].output='ACCEPT'
uci set firewall.@zone[-1].forward='REJECT'
uci set firewall.@zone[-1].input='ACCEPT'
uci add_list firewall.@zone[-1].network='VPN'
# Allow forwarding from VPN zone to OpeVPN or WG VPN
uci add firewall forwarding # =cfg25ad59
uci set firewall.@forwarding[-1]=forwarding
uci set firewall.@forwarding[-1].src='vpn'
uci set firewall.@forwarding[-1].dest='ovpnclient1'
uci add firewall forwarding # =cfg25ad58
uci set firewall.@forwarding[-1].dest='wgclient1'
# Add new SSID to VPN networks
uci set wireless.vpn2g=wifi-iface
uci set wireless.vpn2g.device='mt798111'
uci set wireless.vpn2g.network='VPN'
uci set wireless.vpn2g.mode='ap'
uci set wireless.vpn2g.ifname='ra1'
uci set wireless.vpn2g.encryption='psk2'
uci set wireless.vpn2g.key='goodlife'
uci set wireless.vpn2g.ssid='GL-MT3000-809-vpn'
uci set wireless.vpn2g.vpn='1'
uci set wireless.vpn2g.disabled='1'
uci set wireless.vpn2g.wds='1'
uci set wireless.vpn2g.isolate='1'
uci set wireless.vpn2g.hidden='0'
uci set wireless.vpn2g.disabled='0'
uci set wireless.vpn5g=wifi-iface
uci set wireless.vpn5g.device='mt798112'
uci set wireless.vpn5g.network='VPN'
uci set wireless.vpn5g.mode='ap'
uci set wireless.vpn5g.ifname='rax1'
uci set wireless.vpn5g.encryption='psk2'
uci set wireless.vpn5g.key='goodlife'
uci set wireless.vpn5g.ssid='GL-MT3000-809-5G-vpn'
uci set wireless.vpn5g.vpn='1'
uci set wireless.vpn5g.wds='1'
uci set wireless.vpn5g.isolate='1'
uci set wireless.vpn5g.hidden='0'
uci set wireless.vpn5g.disabled='0'
uci commit
reboot
Then you can use VPN Policy mode to make only the devices connected to VPN SSID to use VPN.
And run the following command to create the corresponding firewall rules for the VPN interface:
iptables -t mangle -A TUNNEL10_ROUTE_POLICY -i br-vpn -m comment --comment "Primary Tunnel" -m mark --mark 0x0/0xf000 -j MARK --
set-xmark 0x1000/0xf000
Fantastic! Thank you.
