If I connect astro management app on the iPad directly to the AsiAir (telescope controller unit) through AsiAir own short-range wifi, everything works!
If I connect to the internal BerylAX wifi (GL MT-3000) everything works!
If I try connecting using home network, it doesn’t - it worked once, then never again!
What I tried:
Putting the Beryl AX into Repeater mode and into Extender mode (not sure what’s the difference)
Putting the AsiAir into a DMZ
Forwarding all the ports relevant for the ASIAIR via port forwarding rule to ASIAIR reserved IP
What I get at best: I can see AsiAir in the AsiAir iPad app, but can’t connect to it.
It has been pointed out to me that the current setup uses two different subnets. How do I configure Beryl AX to use the 192.168.1. subnet without it being the main router and conflicting with the main router?
