Hi!
I recently bought a Beryl AX running on 4.7.0 a couple of weeks ago and started using it as a main router for my new place a few days ago. I am only using it on ethernet mode and it is connected to a cat 5e wall port via WAN. I'm not running a VPN or AdBlock.
Every 15-20 minutes, internet drops for a few seconds and automatically reconnects. I have done some ping tests using ping -t 8.8.8.8 and ran it for an hour and I usually lose 4-10 packets which impacts calls and games greatly. I have attached the ping test here:
ping test.tar (12.6 KB)
I have already tried unplugging the ethernet cables, power cables, and modem cables as well as restarting both the modem and router several times. I have also checked the modem when these disconnects happen, and the internet light is still on but the router light turns off, so I don't think it's an ISP problem.
I have also tried resetting the firmware and reverting to 4.6.9 but the problem persists. The issue affects both the 2.4GHz band and the 5GHz band. It affects all devices on the network including my PC and phone.
I have attached some logs from the past couple of days for reference. Please let me know if there is a fix, thank you!
logread(1).tar (222.5 KB)
logread 2.tar (222 KB)
logread.tar (176 KB)
