Hi, I have been using the Beryl AX for a while and wanted to share my feedback about a few bugs I have found, I am currently on the latest stable version 4.4.6
First, when I am using Network Storage (Samba server) the Wi-Fi starts working strange, when I am on my room the internet just stops working even though I have a good signal on my phone, 2 bars. The internet only works when I am next to the router, like 2-3 meters away. As soon as I disable the Samba Server it starts working normally, I have internet all around my house again. This is strange because the router is next to my room, I know signal or interference isn’t the problem, I have tried changing a lot of things. It doesn’t disconnect from the Wi-Fi, it is just the internet that stops working. Also the SMB Server isn’t stable, stops working quite often when transferring files, I have read this will improve on v4.6. The problem seems to happen only on the 2.4GHz band.
I am using AdGuard Home, OpenVPN Client based on VLAN policy and those work great. However the router used to lose the WAN connection sometimes, I had to restart it every time, I set the router to automatically restart once a week and it’s been working fine, not sure if it was solved on v4.4 though.
Is the Beryl AX is powerful enough to handle AdGuard, OpenVPN Client and Network Storage at the same time?
Also, when I have 2 signal bars on my Android phone (WiFi 6) the upload speed is super slow, only 2mbps whereas the download is normal, once I get closer it gives me my line speed, that is strange as well.
And the last thing, the range, I can only set the TX power to 20dbm (100mW) I would like to set it at 24dbm at least, I have better range on my old Opal SFT1200, I can set it to 1000mW. I have read this will improve on version 4.6
Thank you for reading
