Hi All,
As you can see by the title, I have a Beryl AX and a GL-M2 5G development board.
Everything is working as it should I am having no issues, but I was wondering if its possible to get the same menu's that the Spitz AX for locking bands and all the extra pages involved with the cellular side? I don't mind doing it in the terminal but it would be a nice to have option.
Sorry we haven't added all the cellular options to the travel router yet.
Can you tell me the modem module you use? We'll see if there is a command to achieve it.
Thanks for your reply Cathy. I have the Quectel RM520N-GL
You can lock bands via AT command AT+QNWPREFCFG
Pls refer to the RM520N AT command manual section 5.24 to try
Quectel_RM5x0N_RM521F_Series_AT_Commands_2024_02_07.zip (1.7 MB)
Thanks very much. Will it get added to the travel routers in future?
Sorry do not have this plan at the moment. We will consider and evaluate this requirement
