Hello, everyone:
When Beryl AX (GL-MT3000) is used as a repeater to extend mobile hotspots, it cannot find Android phones; it does find iPad Pro (with 4G LTE)'s hotspot (2.4Ghz).
I tested the router with two Android phones.
- Samsung S21 (European)
- OnePlus Ace 3 (China mainland).
Both phones' hotspots are set to 5 GHz, and WiFi 6 supports WPA2/3. Unfortunately, GL-MT3000 cannot find them.
Occasionally (Rarely), the router can see them, but at 2.4 GHz (though hotspots have been set at 5 GHz).
Setting the hotspots to 2.4 Ghz or/and having their WiFi 6 disabled brought no luck.
However, the router can see the hotspot of iPad Pro (with 4G LTE).
Has anyone else experienced similar issues?
