Beryl AX GL-MT3000 connect 2 devices to USB-C port, possible?
Hi does anyone know wether I can connect 2 external devices to my Beryl AX GL-MT3000?
I'd like to connect both and use them at the same time.
1 An external ssd for file sharing (done)
2 A phone to tether with.
Is this possible on the one USB-C port?
Will both be recognised ?
How should I proceed if it is possible?
That is supported, I think have to add a USB HUB which the HUB with separate power supply.
Thanks Bruce.
I will give it a go.
