Hi, I’m having some issues with my Beryl AX, the internet stops working having a strong signal, literally being like 6 meters away from the router, the signal shows 3 bars on my Samsung device and 2 bars on my iPhone. Curiously the internet works fine when I’m next to the router. But I need to get extremely close. And the walls of my house aren’t the problem because the router used to work fine for over a month and now this started happening suddenly. I even tried different antenna angles. I think it’s like a bug in the router. I need help please, thanks.
And sometimes I can’t even connect to the 2.4 ghz band (6-7 meters away from the router). It used to work fine before all around my house:(
Try choosing a different channel in your wireless settings. Could be heavy signal interference or something causing issues.
It is set to “auto”. Should I try a manual channel?
Yeah you can pick 1, 6 or 11 for the 2.4 GHz spectrum, and preferably a DFS channel for the 5 GHz spectrum.
You can head over to the LuCi interface (there’s a link under “advanced settings” in the web ui) and perform a channel scan to see which channels have the least interference. This is very helpful if you live in a crowded area.
I believe it’s the firmware 4.2.2. Go back to 4.2.1 and your signal will be back to normal
Nope, not working, I changed to channel 6, downgraded to 4.2.1, and even to 4.2.0 and nothing works, still no internet having a strong signal on my room. That bug is so weird, I hope there is a solution. I upgraded to 4.2.2 again since nothing worked
Very strange you’re still having this issue. It could be something hardware related, or a bad firmware install from the factory. I’d try getting GL.iNet to exchange it for you. I have two of these same model and they work great.
I had this problem as well. I downgraded to release 2 of 4.2.1. Once you successfully downgrade, reset the MT3000 by pushing the button for 10 seconds, and everything goes back to normal—at least for me. I tried several release of the firmware versions above 4.2.2, including the stable version, but experienced the same problem. internet becomes very slow.
I tried to disconnect my external USB SSD and seems like it is working fine now, maybe that was the problem, but now I am not able to use my SSD. I was usig an USB extension for the SSD so I don’t think it is some interference
I also discovered that sometimes the internet suddenly drops, it shows a red icon on the glinet app, and then if i restart the router it works normally, it happens like every 4 or 5 days, but I will wait to see it my USB SSD was the problem.
I have this problem too. The Beryl AX intermittently drops out. Sometimes, it does not automatically reconnect (or it does reconnect with minutes, hours, or even days latency). It has been happening through various iterations of firmware. My situation is that I am repeating the signal from a nearby router (signal is strong). Next time it happens, I will try and post logs here.
I tested the beta version 4.5.16 and it seems to be working fine, although I also use vanilla OpenWrt on it
