Hi All,
I know there are issues listen with several locations where a Beryl AX GL-MT3000 can’t Connect to a wifi netwerk using a login screen.
I am currently facing the same. Tried several settings with hot spot login etc but don’t succeed. The router is showing that it gets it’s settings but is stucked and doesn’t connect at all. All Other device get a login screen to accept the wifi rules etc but the Beryl AX refused to move on.
Seems something is wrong in the router. I already did a full reset of the firmware but no succes.
Attached Some log files.
logread.tar (234.5 KB)
Anybody knots wherry it Goes wrong? I tried with 2 Beryl AX routers as I have 2 but same behaviour. On all Other loctations where I used them before no issues at all.
Looking forward to any solutions.
Thanks!
