Beryl AX (MT-3000) no 5ghz Wifi
Hi all,
I am using a Beryl AX (MT-3000) with a VPN mostly via the Repeater function.
with Firmware 4.6.4
I am not able to connect to the 5ghz WiFi created by my Android Samsung Galaxy S23 (lastest version).
The wifif is visible to other devices but it does not appear in the Beryl UI.
If I manually add the wifi, it also does not connect.
Any ideas what I am doing wrong?
In the list of Wifi I can see 5G devices ususally with DFS - pur 5Ghz I can not see in the list
Thanks and kind regards
Do you know which channel the S23 is broadcasting on?
Hi @admon ,thanks for getting back to me
It looks to me that the Beryl AX in General has problems to display networks as 5GhZ
Here a Screenshot ( i am a new user and can only attach one pic)
with
the latest version installed 4.6.8
the phone settings of the Samsung Galaxy S23
the WifiAnalyzer of the PC sitting close to the Beryl - the highlighted two are the phone and the BerylAx
Also on the pic the not found phone in the BerylAX Web UI
I noticed in the beryl some
5ghz are shown as 2.4ghz
Here the copy and past of the found networks from the beryl ax web ui
Blockquote
Available Networks
DIRECT-NJSURFImsHD 2.4G
Gaming-3C4E2E DFS 5G
FRITZ!Box 7362 SL 2.4G
SexytimewithMDMA DFS Mixed
Vodafone-B885 DFS Mixed
WLAN-703097 2.4G
WLAN-277959 2.4G
o2-WLAN30 Mixed
WLAN-440031 Mixed
WLAN-406908 DFS Mixed
Vodafone-12E5 2.4G
UPC1ECF1DF 2.4G
Vodafone-C2C4 2.4G
Drop it like its Hot Spot 2.4G
UPC79AAE83 2.4G
Thanks in advance for your time & help
