Beryl AX (MT3000) Bricked after Upgrade
I just went into the web interface of my GL.iNet MT3000 and was notified that there was an update available. I clicked the update button and waited about 10 minutes, but the web interface did not reappear. I rebooted the router and no lights, no SSIDs, no wired connection. Seems completely bricked.
Any ideas on how to fix this.
First, try restoring the router to factory settings using the reset button on the side of the router.
After the router starts normally. Press and hold the reset button for 10 seconds then release to reset the router to factory settings.
If the factory reset is not working. You might need to follow the Uboot tutorial to debrick your router.
Had to use uboot. That was easy. Thanks.
