Every time I turn on my router, it will get stuck trying to connect to my last Wiregard server. Stopping and restarting the connection won’t fix it. I need to connect to a different server (and then back to the original server if I want to connect to it). Is there a way to fix this?
I don’t think there is a good way in GL.iNet User Interface, it can be done in the Command Line Interface.
I had the same problem until the latest 4.2.2 firmware. If you are keeping settins during system upgrade just delete your VPN profiles and try to re-add them.
I am using the GL.inet app. I believe every time I change servers, it creates a new profile.
What’s your Wiregard server? And from which server to which server?
I am using a Wireguard server from PIA VPN.
