So, I have successfully connected to NordVPN ONCE with the Beryl AX.
I then attempted to authenticate via a captive portal.
On this "captive portal" my NordVPN on both my laptop & phone authenticate fine.
The Beryl AX refused to connect successfully.
Now, I can not get the Beryl AX to connect with NordVPN no matter what network i use.
Have updated to 4.7.0 to see if that helps - No!
Have factory defaulted the router & set up again, still no go.
What the duck is wrong with this?
I have check the current betwork, again via phone & laptop... all work fine, but not with this GL.inet
I would say the upstream provider might block VPN?
So why does it work on the phone & laptop connected to the same provider?
You are using the wrong credentials.
For Nord you need the service credentials instead your login credentials.
Maybe you entered the correct credentials, I don't know.
