I recently purchased a Beryl AX (MT-3000) and have it connected to ethernet and a Wireguard client profil to my homelab with DNS settings is active. When trying to access my services it does not work via my domains just direct IP.
My setup:
I run two piholes in my homelab handling DNS, they are set in the Wireguard profile which works on my phone, tablet and laptops. At home I use *.felix.lan domains to access my services.
The Beryl AX is now on beta firmware 4.6.0 and with the active Wireguard client profile traffic gets routed to my home network and I can access IPs in my home network. But DNS is still routed through the ethernet DNS IP I have at the remote location, not through the tunnel and to my own DNS.
[Interface]
PrivateKey = xxxxx
Address = 10.8.0.6/24
DNS = 10.23.91.4,10.23.91.5
When I ssh into the router and check the /etc/config/dhcp file I see that the resolv file of the ethernet interface is selected option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto' .
When setting it to option resolvfile '/tmp/resolv.conf.d/resolv.conf.wg' in the luci interface it still did not work.
Anyone got ideas how to get this to work? I am confused why my config works everywhere but not in the Beryl ax. I already found a number of posts here and on reddit with similar problems but no real solution
New discoveries: the Beryl is indeed (mostly) using my WG DNS but its doing so very slow. Requests take in some parts multiple seconds and I can see them in the logs of my pihole. It was important to enable Remote access LAN and IP Masquerading in the VPN client settings.
What is still not working is to resolve my local .lan tld domains. Theres something in luci interface about it using lan itself but i dont fully understand that part yet
GL-INET: it would be awesome to see the time since the last handshake with the WG-server in the UI to see if the tunnel is still alive/healthy.
Bonus points for a ping and auto reconnect with new resolv of the endpoint url (when the ip behind the url changes in a DDNS scenario)
I can also observe that queries reach my pihole but not all of them for some reason. When i do a dig on an entry in pihole with a non lan tld it often times out completely or takes around 10secs
In luci ui i cleared search domain and local server entry
Custom DNS was not enabled but enabling it did not make a difference. Calling something like http://kirby.felix gets resolved by the pihole. Thus I am sure openwrt is somewhere still blocking my *.lan domains.
Why DNS resolution does not work for the entire traffic i do not know
