I’m using a Beryl AX (GL-MT3000).
I have it for a while now and whenever I try to use it as a repeater, it cannot find any WiFi.
When i choose only 2.4GHz i can find some wifi networks but fails to connect.
It cannot find tethering from my phones both IOS Iphone and Android Pixel.
I have also a wireless router which I use in Greece and still cannot find the router.
The only way I can successfully use it is via Ethernet.
I’m using the latest Version 4.5.16
Wireguard Client is enabled. Wireguard Server enabled at home on another router.
I found similar tickets suggesting rolling back to 4.2.2 .
Also found some tickets mentioning changing country via Lucy. Bought the router from UK and use it all around Europe. I cannot find anywhere this setting.
Current setup is 00 but still Beryl Fails to find any WiFi networks while in Greece. Also there are no Advance setups for Beryl to choose a different country from Drop down. Found a video from GLinet showing how to change the country but that’s not applicable to Beryl.
Any suggestion how to change the country? With what value? or any other suggestions?
At this point not sure the country code is the issue because from a google search, e.g a Google Pixel hotspot usually is on Channel 6 so ideally should be visible with country 00
Just realized that the channels on my Bery Wireless Settings are preselected.
for 2.4GHz is channel 11 and for 5Ghz is channel 44. Can this be a problem? Should I change them to Auto?
Ok so in the end it worked without any change.
Not sure how or why but without changing anything I can see all the WiFIs and I can connect to my phones or my portable router which is great. Didn’t have to change the country or downgrade to a different firmware. All I did was a reboot, connected to LuCI, not specific change.
There seem to be some kind of specific issue with the wireless connectivity at my current’s accommodation router.
4 different networks worked except 1 which I can also use via ethernet.
