Is it possible to use the Beryl Ax travel router as a drop in gateway with T-mobile home internet router?
I can not disable DHCP on the T-mobile router.
If you can’t disable DHCP nor modify the settings it will be difficult to get the Drop-In mode running.
You could use normal routing mode instead.
Thanks
Will do that.
