just started using my beryl ax router. my use case is as a wifi repeater. i attempted to connect to my home eero network, and it won't connect. The web portal icon is orange and just says
Connection failed, will retry later…
While attempting to reconnect, your router will periodically scan for Wi-Fi networks, and your guest Wi-Fi network will be temporarily unavailable during this scan.
When I switch to a wifi network broadcast by my android hotspot, everything works fine however.
I also found this amazon review which agrees that maybe this is just an eero problem? Amazon.com: Customer reviews: GL.iNet GL-AXT1800 (Slate AX) Pocket-sized Wi-Fi 6 Gigabit Travel Router, Extender/Repeater for Hotel&Public Network, VPN Client&Server, OpenWrt, Adguard Home, USB 3.0, Network Storage, TF card slot
Am I doing something wrong? Are there wifi networks that this device is unable to use as a repeater? The goal of this router was to turn random 3rd party networks into something uniform and trustworthy. I'm concerned i'll continue to find other wifi networks that don't work, so i wanted to get ahead of it and see if there was something i was missing.
thank you!
