Hey all,
Everytime I run a test on speedtest.net, it slows climbs then shoots to to 100+ and reboots.
Did it on every firmware I’ve tried.
Thanks.
Hey all,
Thanks.
Do you use a regular power plug?
Yeah, original one from the box.
Edit: I found the problem, it was the power surge board I was using. Took it out and just went straight into the wall and it works with no reboot.
Thanks.
Cannot think why this could be a reason though.
Everytime I try with it plugged into the board it works but crashes and quickly reboots the wifi ssids, when I just plugged straight into the wall it works fine no crashes when doing speedtests.
Probably just the board that I need to replace.
