Beryl AX - unable to connect to one specific network (no DHCP)
Ive had a reproducible issue here connecting my Beryl to 1 specific home ISP router on 5GHz only and getting an IP.
Beryl AX running 4.9 beta 4 (but also on 3,2 and 1 but cant confirm older).
Beryl AX running in Router mode to repeat the wifi via its own network.
ISP Router is IndoHome which is a rebadged Huawei HG8145V5.
Importantly its set to WPA/WPA2PSK and “TKIP&AES” as a default. An old encryption scheme. This is the default shipped.
Problem
  • Beryl connects to the ISP router using 2.4ghz, DHCP works, an IP is assigned and no issues.
  • However on 5GHz it connects BUT DHCP allocation never completes, times out and gets into a reconnect cycle loop.
  • If i MANUALLY assign an ip address, subnet etc it works on 5GHz.
No other devices at all have this issue.
Every connection attempt shows the same sequence. The 4-way handshake reaches message 3 and then logs an RSNIE mismatch:
7981@C15L3,PeerPairMsg3Action() 6640: ===>Receive msg 3
WiFi@C15L1,RTMPCheckRSNIE() 4543: WPA/WPAPSK IE mis-matched
IPv6: ADDRCONF(NETDEV_CHANGE): apclix0: link becomes ready
Despite the mismatch the association completes and gl-repeater reports connected:
7981@C09L2,LinkUp() 3102: BssType=1, AID=91, ssid=[SSID], Channel=149, CentralChannel = 155
gl-repeater: connected to [SSID] [BSSID]
gl-repeater: [no-ip] schedule recover check delay: 15 ip_wait_time: 15
DHCP discovers are sent but no offer is ever received:
netifd: wwan (4315): udhcpc: started, v1.33.2
netifd: wwan (4315): udhcpc: sending discover
After 15 seconds, gl-repeater gives up and tears down the connection:
gl-repeater: [no-ip] no ipv4 address on wwan reconnect to known bss
gl-repeater: remove "apclix0" from wwan
This cycle repeats indefinitely. The Beryl then restores its own downstream 5 GHz radio to its resting channel and reschedules a retry in 30 seconds:
gl-repeater: rax0 restore channel to 40
gl-repeater: switch in 30 seconds..
Pool exhaustion, ip conflict and mac filtering ruled out.
A summary (using AI because of my own random jumpy notes):
The upstream router is configured with WPA/WPA2 mixed mode and TKIP&AES. This is a legacy security configuration that causes ambiguity in the RSN Information Element (RSNIE) cipher suite negotiation during the 4-way handshake. The IE presented in handshake message 3 can differ from what was advertised during association, which the MT7981 driver correctly detects and logs as WPA/WPAPSK IE mis-matched.
The driver does not drop the connection on this error — it completes the association, which is the correct behaviour for compatibility with older routers. However, the upstream router enters a half-open session state for that client as a result of the inconsistency. In this state it processes unicast traffic normally but silently drops broadcast traffic from the client.
DHCP discover packets are sent to the broadcast address 255.255.255.255 and are therefore discarded before reaching the router's DHCP server. This explains why a pre-configured DHCP reservation on the router makes no difference — the reservation is irrelevant if the discover never arrives.
Assigning a static IP bypasses broadcast entirely. The Beryl ARPs for the gateway via unicast, which the router handles normally, and the connection functions correctly.
The 2.4 GHz band on the same router works via DHCP because the cipher suite negotiation path differs slightly between bands on this router, resulting in a consistent RSNIE and no half-open session state.
The RSNIE mismatch log line is the key indicator. The combination of:
  • Association succeeding
  • RSNIE mismatch logged
  • DHCP failing silently
  • Static IP working
  • DHCP reservation also failing
Do you use any form of wpa2 mixed as cipher?
These are not stable, you want to use the non mixed variants on both routers.
Then forget network on Beryl and try again.
Ideal world no.
Real world, these are ISP supplied routers to which most customers do not have admin access to the level they can change ciphers (or in fact have the knowledge to).
The Beryl wont connect to these currently without manual workarounds.
Its pretty common here for ISPs to supply routers to end users with locked completely or with very few options exposed to change.
Ive so far come across this issue in 1 large well known international hotel chain in Malaysia, this house here in Indonesia (where i have managed admin access but cant change things) and another elsewhere in Indonesia (Guest house, different isp, same router rebadged.)
Hmm that is crazy, I know in my country before the law passed that you can hold your own isp router, I always were allowed to login, there is not a sticker on the back with these creds?
Do you have any other internet source available, such as a wired WAN connection or USB tethering, so that the device can be connected to GoodCloud according to the guide below? This would allow us to perform a remote inspection.
https://docs.gl-inet.com/router/en/4/tutorials/technical_support_via_goodcloud/
Please also send us the MAC address and the router password via private message so that we can access the device.
That’s exactly the problem in real-world usage. A lot of ISP-provided routers are heavily locked down, especially in hotels, apartments, and guest houses. Most regular users either don’t have admin access or wouldn’t even know where to change cipher settings if they did.
If the Beryl struggles to connect without manual tweaks, it becomes a usability issue rather than just a configuration issue. Your examples from Malaysia and Indonesia show this isn’t an isolated case either, especially with rebadged ISP routers using the same restricted firmware.
I think its a specific use case for this product.
A Beryl being a travel router is far more likely to connected to a number of different upstream gateways, all of which could be configured in different ways and the user will have no control over.
I agree the mixed cipher here is old, obsolete and poor but unlike a home connection, i have no say in it. It just “is” on this router/isp combo. So the Beryl not connecting requires workarounds that id rather not do (and some users may not know how to do).
Upstream compatibility is far more important when you have no direct control of that upstream kit.
I cant actually test or connect to goodcloud from here as i leave tonight. I have logs but no more than that. Wont be back in this house until next year.
I completely agree. I think this is what separates a travel router from a typical home router. At home, you can usually log into the ISP gateway and change the security settings if needed. When you're traveling, you rarely have that option. You're expected to connect to whatever the hotel, apartment, or ISP has configured.
That's why upstream compatibility is so important. If the Beryl requires users to manually adjust settings every time it encounters an older or mixed-cipher network, it's going to frustrate a lot of people who bought it specifically for hassle-free travel. Hopefully the logs you've provided are enough for the developers to identify whether this can be addressed in a future firmware update.
