Beryl AX USB HDD Support
I have a WD 1TB HDD USB drive.
I had it plugged into the Beryl (not AX) for 2 years and it worked fine as a NAS (albeit a bit slow). No issues and was totally stable.
I have now replaced my Beryl for a Beryl AX, using the same HDD, and the drive is completely unstable. Sometimes it appears, sometimes it drops out. I see many differing errors in the log, nothing consistent, just errors and the drive drops out. If it’s helpful, I can capture some and post here.
Why am I having this issue when this same drive worked fine with the older model?
There is no external power supply to the HDD, just the USB connection.
Thank you.
I would still count on a power issue.
Could you set up an active USB hub in between Beryl AX and WD HDD? Just for testing.
Don’t have a powered hub to try. I hope that’s the issue as I will order a SSD and hope the power is not an issue for that. Its not clear why the USB port won’t supply the required power for a standard HDD when it has a USB 3.0 port.
Definitely a power issue. Seems (some, not all?) the Beryl AX have unstable or non-standard voltage supply or regulation at the USB-A port. Changing power supplies TO the Beryl AX does not help.
A powered hub or Y-cable will probably be your only options.
I had a similar issue where a 5G modem will not fully boot when plugged into the Beryl AX, however it works fine on the Slate AX (AXT1800).
What is a Y cable?
It would seem this would be a warranty issue then if the port is not working to spec.
A Y splitter cable. (examples) Much like a powered USB hub, but for a single device. Cable has 3 connectors, one for the host (Beryl AX in this use case) one for the connecting device (USB HDD) and one for additional power supply (which in good quality cables will be connected only to the USB HDD). You would, however, need either a multi-port power supply or a second power supply to connect to the HDD.
Have a Y cable on order to test in my situation.
GL.iNet staff have not responded to my similar question about warranty issue, I agree though it seems very much like the USB-A port in the Beryl AX does not meet the USB standard when under actual load (when nothing is connected it seems borderline).
Thanks. Looking at those cables most of them appear to simply be splitters so two devices can be connected to a single USB port.
Do you have a link to one that actually does what you are talking about and will inject power from the third connector? I am not seeing anything that states it does that.
OK. I found one that is what you are talking about:
Amazon.com: ALINNA Black USB 3.0 Female to Dual USB Male Extra Power Data Y Extension Cable Splitter Adapter for 2.5" Mobile Hard Disk : Electronics
Thanks for the pointer. Will order one and see what happens.
Just to follow up, the splitter cable connected to an additional power source allows the drive to work fine. So it is an issue with the USB port on the MT3000 not providing enough power.
I'm planning to do this in my BerylAX but without the Y splitter, since you are using an HDD, do you think SSD is a lot better to use because it requires less power?
I switched to a SSD and had the same issue and still need the Y cable. But different SSDs might have different power requirements.
Since we don't have your SSD, you need to work it out by yourself.
The product page (GL-MT3000 / Beryl AX - GL.iNet) says:
Power Input Type-C, 5V/3A
Power Consumption <8W
Formula: Watt = Volt * Ampere
Calculation: (8 watts) / (5 volts) = 1.6 amperes
So, 3-1.6 -> 1,4 Ampere is the maximum provided power at the USB port. Now take a look at the datasheet of your SD drive, or take a multimeter and measure it yourself.
There are "USB Power Meter" (this is your Google search term) devices with a histogram on the display. Just try it without and with SSD, and look at the difference. Is enough power left for the Beryl?
My USB power tester is from Yojock over Amazon for 25 Ruro. Good enough for simple testings.
Everything should work with roundabout 5V. If there is a drop in the Volt, it may be an issue within the power supply itself. We need to focus on the ampere.
