IOIO
I have the Beryl Ax and I'm having trouble determining if it is capable of having VPNs tied to specific networks (eg. main SSID or guest SSID)?
What I would like to do is have my main network go through a VPN like mullvad and the guest have no VPN or a different VPN.
Is this possible?
I don't believe this is currently possible, but there are some similar features in the 'In Discussion' section of Update on 2023 feature requests implemented starting firmware v4.3 and ongoing development
You can try to use Based on the VLAN Mode disable using VPN for guest networks.
