Beryl AX with 4.11 and VLAN / Tailscale problems
with firmware 4.11 and VLAN Support everything is fine as long Tailscale is not used.
When using VLANS on LAN interface and active Tailscale, no internet access is available on VLANs.
Anything I can fix myself?
Thanks in advance.
I had to roll back my firmware on Flint 4 v4.11 totally screws up tailscale
For me it is working fine, except with VLAN enabled.
Wouldn’t bind for me at all wouldn’t even give me the link to bind it just kept giving out a error hopefully they’ll fix it soon
Same boat here — 4.11 definitely broke something with Tailscale for several of us. I rolled back on my Beryl AX as well and everything went back to normal, VLANs included. Worth reporting it to support with your logs so they can address it in the next release. Good luck.
Thank you for reporting this issue.
Could you please provide more details about your VLAN and Tailscale configurations or share screenshots of the relevant configuration pages? This will help us reproduce the issue locally and investigate it further.
