Beryl AX (GL-MT3000) AX3000
Firmware 4.5.0 release 8
Ethernet DHCP LAN connection to hotel
Having issues with this router. Some apple devices can see the network but take numerous attempts before it will connect to the WiFi.
Also having lots off issues where the connection drops momentarily. For example downloading files the download starts and seems to be progressing fine then connection is lost and download fails. The blue LED on the front of the router flashes then connection restores and LED then remains constant. If I connect to the hotels guest network I have no issues and the download completes no issues.
Extract of log below
Mon Apr 8 00:42:47 2024 kern.info kernel: [2245926.998446] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Mon Apr 8 00:42:47 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Mon Apr 8 00:42:47 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Mon Apr 8 00:42:47 2024 daemon.notice netifd: wan (27784): udhcpc: received SIGTERM
Mon Apr 8 00:42:47 2024 daemon.notice netifd: wan (27784): udhcpc: unicasting a release of 172.20.4.38 to 172.20.0.1
Mon Apr 8 00:42:47 2024 daemon.notice netifd: wan (27784): udhcpc: sending release
Mon Apr 8 00:42:47 2024 daemon.notice netifd: wan (27784): udhcpc: entering released state
Mon Apr 8 00:42:47 2024 daemon.notice netifd: wan (27784): Command failed: Permission denied
Mon Apr 8 00:42:47 2024 daemon.notice netifd: Interface ‘wan’ is now down
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Withdrawing address record for 172.20.4.38 on eth0.
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Leaving mDNS multicast group on interface eth0.IPv4 with address 172.20.X.XX.
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Interface eth0.IPv4 no longer relevant for mDNS.
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Interface eth0.IPv6 no longer relevant for mDNS.
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:82ba.
Mon Apr 8 00:42:47 2024 daemon.info avahi-daemon[5247]: Withdrawing address record for fe80::9683:c4ff:fe27:82ba on eth0.
Mon Apr 8 00:42:47 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Mon Apr 8 00:42:47 2024 kern.info kernel: [2245927.063356] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Mon Apr 8 00:42:47 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Mon Apr 8 00:42:47 2024 daemon.warn dnsmasq[5528]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Apr 8 00:42:47 2024 kern.info kernel: [2245927.081410] hook is going to be disabled !
Mon Apr 8 00:42:47 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Mon Apr 8 00:42:47 2024 user.notice kmwan: config json str={ “op”: 3, “data”: { “cells”: [ “wan” ] } }
Mon Apr 8 00:42:47 2024 kern.debug kernel: [2245927.449935] kmwan: Delete node:wan
Mon Apr 8 00:42:51 2024 kern.info kernel: [2245931.157436] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Apr 8 00:42:51 2024 kern.info kernel: [2245931.166069] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Apr 8 00:42:51 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Mon Apr 8 00:42:51 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Mon Apr 8 00:42:51 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Mon Apr 8 00:42:51 2024 daemon.notice netifd: wan (29644): udhcpc: started, v1.33.2
Mon Apr 8 00:42:51 2024 daemon.notice netifd: wan (29644): udhcpc: sending discover
Mon Apr 8 00:42:51 2024 daemon.notice netifd: wan (29644): udhcpc: sending select for 172.20.X.XX
Mon Apr 8 00:42:51 2024 daemon.notice netifd: wan (29644): udhcpc: lease of 172.20.X.XX obtained, lease time 3600
Mon Apr 8 00:42:51 2024 daemon.info avahi-daemon[5247]: Joining mDNS multicast group on interface eth0.IPv4 with address 172.20.X.XX.
Mon Apr 8 00:42:51 2024 daemon.info avahi-daemon[5247]: New relevant interface eth0.IPv4 for mDNS.
Mon Apr 8 00:42:51 2024 daemon.info avahi-daemon[5247]: Registering new address record for 172.20.4.38 on eth0.IPv4.
Mon Apr 8 00:42:51 2024 daemon.notice netifd: Interface ‘wan’ is now up
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain test
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain onion
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain localhost
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain invalid
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain bind
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using only locally-known addresses for domain lan
Mon Apr 8 00:42:51 2024 daemon.info dnsmasq[5528]: using nameserver 172.20.0.1#53
Mon Apr 8 00:42:51 2024 kern.info kernel: [2245931.446251] hook is going to be enabled !
Mon Apr 8 00:42:51 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Mon Apr 8 00:42:51 2024 user.notice kmwan: config json str={ “op”: 2, “data”: { “cells”: [ { “interface”: “wan”, “netdev”: “eth0”, “track_mode”: “force”, “addr_type”: 4, “tracks”: [ { “type”: “ping”, “ip”: “1.1.1.1” }, { “type”: “ping”, “ip”: “8.8.8.8” }, { “type”: “ping”, “ip”: “208.67.222.222” }, { “type”: “ping”, “ip”: “208.67.220.220” } ] } ] } }
Mon Apr 8 00:42:51 2024 kern.debug kernel: [2245931.735206] [add_dev_config 307]add node success. iface:wan, dev:eth0, ifindex:2
Mon Apr 8 00:42:52 2024 daemon.info avahi-daemon[5247]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:82ba.
Mon Apr 8 00:42:52 2024 daemon.info avahi-daemon[5247]: New relevant interface eth0.IPv6 for mDNS.
Mon Apr 8 00:42:52 2024 daemon.info avahi-daemon[5247]: Registering new address record for fe80::9683:c4ff:fe27:82ba on eth0.*.
Any ideas?
