My new Beryl AX3000 in factory set mode, using Starlink via POE is only allowing one client on 2.4G and one on 5G channel. I cannot get online with any other clients.
I purchased exactly the same kit to run my Starlink in the campervan and few months back and out of the box it works perfectly. This one is to run Starlink in my boat off 12v.
Any ideas why my latest AX3000 is doing this please? Be aware I’m not too technically minded ![]()
Please use the attached power supply to power the Beryl AX.
Is it connected to the main wifi? not guest wifi.
Just connected to the main WiFi only.
How about this issue now? May I know if the router works when it uses the attached power supply?
I now have it all working thank you.
I think there is definitely a setting up procedure before connecting the Starlink. But all good working off a 12v system now ![]()
