Hi, I have bought a brand new Beryl router. I am not able to set up any VPN as any website relating to VPN seems to be getting blocked. Other websites are working fine. I have not changed anything in the router. Does it come with pre-installed site blocks?
Can you describe in another way? I cannot fully understand. Do you mean you cannot set up vpn at all? which vpn service? which region are you using the router?
I was trying to set up Nord VPN. If were to attempt to go to www.nordvpn.com, i am not able to reach the website. It is the same for expressvpn website. But google.com, surfshark etc are working
The box does nothing to block these website. Maybe it is your ISP or pc’s firewall?
