If you use a wireless device, and connect to your home wifi on 192.168.1.x, you can get to the internet fine?
If you use a wireless device, and connect to the Beryl via wifi, you can access the Beryl GUI at 192.168.8.1, and your wireless device draws an IP in the 192.168.8.x range?
Using your wireless device then, on the GUI, under “repeater”, you scan for your home wifi, enter your password, and it connects to your home router?
All of the above is “yes”, but then your wireless device doesn’t have a connection to the internet?
