[Beryl] DNSCrypt-proxy abruptly not working anymore
Beryl, openwrt-mt1300-3.212-0301-BETA1.bin, connected by cable
(Without even touching the router) since ~ 16:30 UTC the builtin DNSCrypt-proxy (MORE SETTINGS | Custom DNS Server | Dnscrypt-Proxy Settings)¹ does not respond to requests anymore:
2
System Log shows repeating lines like
Sat Mar 26 16:42:32 2022 daemon.info dnscrypt-proxy[31487]: dnscrypt-proxy Refetching server certificates
Sat Mar 26 16:42:47 2022 daemon.err dnscrypt-proxy[31487]: dnscrypt-proxy Unable to retrieve server certificates
Same on Lab-Beryl (same FW).
Please quickly find a solution for other customers (mine in next post).
¹ the settings (same /w cisco, dnscrypt-eu-dk, yandex, … as selected server)
possible solutions:
  • configure DNS over TLS instead of Dnscrypt-Proxy
  • upgrade to latest snapshot (in my case openwrt-mt1300-3.212-0326.bin)
  • wait for GL-inet to react
edit: @GL-inet:
funny: DNS resolution works again but System Log still shows loads of entries:
Sat Mar 26 18:28:55 2022 daemon.info dnscrypt-proxy[6526]: dnscrypt-proxy Refetching server certificates
Sat Mar 26 18:29:10 2022 daemon.err dnscrypt-proxy[6526]: dnscrypt-proxy Unable to retrieve server certificates
Sat Mar 26 18:29:40 2022 daemon.info dnscrypt-proxy[6526]: dnscrypt-proxy Refetching server certificates
Sat Mar 26 18:29:55 2022 daemon.err dnscrypt-proxy[6526]: dnscrypt-proxy Unable to retrieve server certificates
Sat Mar 26 18:30:28 2022 daemon.info dnscrypt-proxy[6526]: dnscrypt-proxy Refetching server certificates
Sat Mar 26 18:30:43 2022 daemon.err dnscrypt-proxy[6526]: dnscrypt-proxy Unable to retrieve server certificates
Thanks for reporting. Checking.
What is the reason that the server cannot be connected?
Only some server can still work. Like cisco works for me here.
Maybe could update something about OpenSSL/Certificates to deal with it.
DNSCrypt-proxy server could choose Yandex
adguard-dns-ns1 works again - maybe it was just down?
tried a few today - these are the results from Beryl, openwrt-mt1300-3.212-0301-BETA1.bin:
server          - reply time
adguard-dns-ns1 - 3s
 adguard-dns-ns2 - time out ("to")
 bikinhappy-sg   - to
cisco           - 3s
 cs-de           - to
 d0wn-fr-ns1     - to
 d0wn-se-ns1     - to
 dnscrypt.eu-dk  - to
 fvz-anyone      - to
 securedns       - to
yandex          - immediate
That’s surely not satisfying.
Tried the same with openwrt-mt1300-3.212-0329.bin
server          - reply time
adguard-dns-ns1 - immediate (i)
 bikinhappy-sg   - to
cisco           - i
 cs-de           - to
 d0wn-fr-ns1     - to
 d0wn-se-ns1     - to
 dnscrypt.eu-dk  - to
 fvz-anyone      - to
 securedns       - to
yandex          - i
Does the servers list need a severe cleanup or are there just compatibility/cert issues with many servers?
Checked further. Some of the servers are down.
Need to update the whole Dnscript to version 2.
just tested again: Out of above list only cisco answers RN using openwrt-mt1300-3.212-0301-BETA1.bin. Using openwrt-mt1300-3.212-0329.bin it’s like yesterday.
Whilst you’re at it: Pls add a 2nd (‘backup’) DNS resolver.
Wouldn’t have helped me (as adguard-dns-ns1 and 2 are down) but would help in many cases (making the product more reliable and reducing support effort).
Thank you!
This issue has been fixed and snapshot 0401 will be available for testing.
Unfortunately quite the opposite:
In openwrt-mt1300-3.212-0401.bin none of the DNSCrypt-proxies work anymore. Furthermore you removed working ones like adgurd-dns-ns1.
Pls fix, I’ll switch back to openwrt-mt1300-3.212-0331.bin for now.
I tested openwrt-mt1300-3.212-0401.bin and the DNSCrypt works.
Which server worked for you? All I tried gave timeout.
My version says Compile Time 2022-04-01 10:05:24 in WebUI | UPGRADE, did you use that very version?
edit: Pretty strange… Re-flashed …-0401.bin, appears to work now.
Missing servers are still a thing though.
OK understand. Maybe a big update in firmware 4.x.
The real issue is that gl-sdk currently depends on dnscrypt-proxy. So I can’t even take it off and replace it with dnscrypt-proxy2 (which is currently more supported).
If you could make gl-sdk independent of dnscrypt-proxy, then it would be possible to replace it with version 2 without breaking the router.
Fixed the list in dnscript in 3.212 beta. Maybe this solve the problem for now.
I think longer term it would still be better to break the dependency between gl-sdk and dnscrypt-proxy so it can be replaced. Because currently instaling dnscrypt-proxy2 just breaks the front end (asked to set a new password and can’t log into the UI).
The router is install dnscrypt-proxy v1,that is different with dnscrypt-proxy2.
When used dnscrypt-proxy v1,only one DNS server could to choose.
Yes, I know, but the reason it can’t be replaced is that gl-sdk relies on dnscrypt-proxy (v1).
In github.com,you could find more dnscrypt-proxy v1
How can I upgrade to dnscrypt-proxy version 2? I need this to enter my custom dns over tls server I want to use.
