Hello All,
My Beryl drops all Wifi clients and either does not allow them to reconnect or stops broadcasting SSID altogether usually after some time usually about an hour.
Upgrading firmware and trying different power sources has not fixed this.
Has anyone else experienced this?
Which firmware did you upgrade to? snaptshot beta5/beta6?
If the wifi disappear for a period of time, e.g. 1 minutes, which seems that the router just rebooted, you may try changing power adapter.
If the wifi dispear and just come back quickly, it should be software problem and hopefully it is fixed in the snapshot. Can you confirm?
Tried beta5. Just tried beta6. Wifi disconnected and stopped broadcasting after several hours.
Changing firmware and power source did not fix. Working with CS to replace.
