I’m running 3.211 on our Beryl router and numerous times per day the wifi drops off and returns a few seconds later. This is causing issues with zoom calls, streaming, etc.
Internet is through Ethernet WAN and I have the repeater off (set to not scan and connect).
I have one windows 10 connected through a LAN port, a Raspberry pi on the other LAN, a windows 11 laptops and several iPhones and iPads on wifi.
Try to set a different Wifi name (SSID) for 2.4GHz and 5GHz.
I assume the drops will only happen at 5GHz. The reason could be interference with other frequencies → change channel to a free one.
Okay. This is what the manufacturer of the VHF just sent me.
The logs are pointing to something with the router. I’d advise the user to disable all power saving mechanisms in the router and make sure it’s using the latest FW on it.
We’re getting lots of beacon loss events and that’s causing the the disconnects. Two things to note is that he’s using both channel 11 and 40 MHz channels and we’ve seen issues with either of those things in other units. I’d recommend changing one of those and seeing if it works. If it doesn’t, then change both.
