Beryl GL-MT1300, Work fine until i Upgrade to BETA “openwrt-mt1300-4.1.0-1019-1666156174”
it Never Start Back , Can not Acces it , No ip 192.168.8.1, it DEAD/RIP
How to can revive it !! or Revert to old Firmware
Message also alzhao
I do not work for and I am not directly associated with GL.iNet ![]()
Can you use uboot debrick and flash firmware back?
Re Flash Firmware Work but i take 5 time to do it , i take the firmware before the latest and its work
the problem i got is the router do not give the DHCP 192.168.8.1 (Give me the ip 169.254.*) to access the router take many try (or was not patient for it)
Now its Fix
169.254.x.x is a Automatic Private IP Addressing (APIPA) is a DHCP fail-safe that protects a computer system from failure. It invokes a standby mechanism for local Internet Protocol version 4 (IPv4) networks supported by Microsoft Windows. With APIPA, DHCP clients can obtain Ip addresses
Glade to here you got it working again.
