I have a GL-iNet Beryl GL-MT1300 travel router and it self identify itself on the ISP router as “GL-MT1300”
How can I change the localhost name from the default name ‘GL-MT1300’ to something else?
You can change in /etc/config/network
Thanks
After playing a little with it, I found out how to do it:
I changed the hostname value in /etc/config/system
I used WinSCP app, the guide for WinSCP I found it here:
Thank you, this worked for me also
I edited it using JuiceSSH on Android.
