Beryl GL-MT1300 not visible 4G modem Huawei E3372s-153
Version Firmware: 3.201
There are two router, on GL-AR750-Ext (Slate) modem visible and works, on the second router GL-MT1300 (Beryl) - does not see! Please, fix it.
Do you mean tethering? or repeater?
I mean tethering, hi-link modem
Results of commands with a connected modem 3372-153 to Beryl GL-MT1300:
ls /dev/
ifconfig -a
logread
Sorry the file contains no data. Can you pls check?
sorry, reuploadGLINET.zip (12.3 KB)
Carefully looked at the logs and figured out the problem itself, the modem was connected via the USB the extension with blue, so the modem was not visible, he told another extension agent white, the modem is visible through it! What do you think this is due to non-compatibility of USB punctures?
Maybe help the installation of additional plugins in the firmware? Any ideas?
So USB2.0 cable works but USB3.0 cable does not?
I am not sure if USB2.0 or 3.0 make difference. Maybe just cables too long.
