I just ordered two Beryls (GL-MT1300s), but neither of them is able to connect to my home WiFi. The home WiFi is using WPA2 Personal, and running with the same ESSID on both 2.4GHz and 5GHz. I’ve tried connecting on both the 2.4GHz and the 5GHz, as well as moving the Beryl closer to my primary router.
The UI shows “success” with joining, but then the main page shows no connection to the internet. My main router shows a brief (several seconds) connection from the Beryl, but no data.
When I look at the Beryl’s logs, this appears to repeat every 5 seconds or so (one full loop below):
Sun Sep 6 20:26:21 2020 daemon.notice netifd: Interface 'wwan' has link connectivity Sun Sep 6 20:26:21 2020 user.info : [ 2894] gl-wifi-core>> bIsStaEnabled=1 Sun Sep 6 20:26:26 2020 daemon.notice netifd: Interface 'wwan' is enabled Sun Sep 6 20:26:26 2020 daemon.notice netifd: Interface 'wwan' is setting up now Sun Sep 6 20:26:26 2020 daemon.notice netifd: wwan (6276): udhcpc: started, v1.30.1 Sun Sep 6 20:26:26 2020 daemon.notice netifd: wwan (6276): udhcpc: sending discover Sun Sep 6 20:26:26 2020 daemon.notice netifd: Network device 'apclix0' link is down Sun Sep 6 20:26:26 2020 daemon.notice netifd: Interface 'wwan' has link connectivity loss Sun Sep 6 20:26:26 2020 daemon.notice netifd: wwan (6276): udhcpc: read error: Network is down, reopening socket Sun Sep 6 20:26:26 2020 daemon.notice netifd: Network device 'rax0' link is down Sun Sep 6 20:26:27 2020 daemon.notice netifd: wwan (6276): udhcpc: received SIGTERM Sun Sep 6 20:26:27 2020 daemon.notice netifd: Interface 'wwan' is now down Sun Sep 6 20:26:27 2020 daemon.notice netifd: Interface 'wwan' is disabled Sun Sep 6 20:26:27 2020 daemon.notice netifd: Interface 'wwan' is enabled Sun Sep 6 20:26:27 2020 daemon.notice netifd: Network device 'rax0' link is up Sun Sep 6 20:26:27 2020 daemon.notice netifd: Network device 'apclix0' link is up Sun Sep 6 20:26:27 2020 daemon.notice netifd: Interface 'wwan' has link connectivity Sun Sep 6 20:26:27 2020 daemon.notice netifd: Interface 'wwan' is setting up now Sun Sep 6 20:26:27 2020 daemon.notice netifd: wwan (6458): udhcpc: started, v1.30.1 Sun Sep 6 20:26:28 2020 daemon.notice netifd: wwan (6458): udhcpc: sending discover Sun Sep 6 20:26:31 2020 daemon.notice netifd: wwan (6458): udhcpc: sending discover Sun Sep 6 20:26:34 2020 daemon.notice netifd: wwan (6458): udhcpc: sending discover Sun Sep 6 20:27:01 2020 daemon.notice netifd: Network device 'apclix0' link is down Sun Sep 6 20:27:01 2020 daemon.notice netifd: Interface 'wwan' has link connectivity loss Sun Sep 6 20:27:01 2020 daemon.notice netifd: wwan (6458): udhcpc: read error: Network is down, reopening socket Sun Sep 6 20:27:01 2020 daemon.notice netifd: Network device 'apclix0' link is up Sun Sep 6 20:27:01 2020 daemon.notice netifd: Interface 'wwan' has link connectivity Sun Sep 6 20:27:01 2020 user.info : [ 2894] gl-wifi-core>> bIsStaEnabled=1 Sun Sep 6 20:27:01 2020 daemon.notice netifd: wwan (6458): udhcpc: received SIGTERM Sun Sep 6 20:27:01 2020 daemon.notice netifd: Interface 'wwan' is now down Sun Sep 6 20:27:01 2020 daemon.notice netifd: Interface 'wwan' is disabled Sun Sep 6 20:27:26 2020 user.info : [ 3494] gl-wifi-core>> Join wifi failed! (code=-5) *** Sun Sep 6 20:27:27 2020 daemon.notice netifd: Network device 'apclix0' link is down Sun Sep 6 20:27:27 2020 daemon.notice netifd: Interface 'wwan' has link connectivity loss Sun Sep 6 20:27:27 2020 daemon.notice netifd: Network device 'apclix0' link is up Sun Sep 6 20:27:27 2020 daemon.notice netifd: Interface 'wwan' has link connectivity Sun Sep 6 20:27:27 2020 user.info : [ 2894] gl-wifi-core>> bIsStaEnabled=1 Sun Sep 6 20:27:32 2020 daemon.notice netifd: Interface 'wwan' is enabled Sun Sep 6 20:27:32 2020 daemon.notice netifd: Interface 'wwan' is setting up now
What’s going wrong? What does code -5 mean? And what can I try next?
