I recently got a Beryl (GL-MT1300) to use with my UML290 Verizon USB Aircard. Looking at the Manual, it says the UML290VW (Verizon) should work with the router (confirmed tested by GL.iNet/steven). I saw someone else had a similar issue, but they moved to a different USB Card. What do I need to do in order to make the UML290 work? I have tried auto and it never connects. Doing manual and entering in the details (based on another mobile router I have that works with it) I can get it to connect, but it doesn’t have the USB Aircard details (like the IMEI) or get an IP Address. After a minute it disconnects and tries to reconnect with the same result (and just repeats this process).
Anyone have any thoughts on what needs to be done to make the UML290 work (manual settings, adjustments in the router, etc…)?
qmi is not an option in Proto. Changing the Device from /dev/cdc-wdm0 to /dev/ttyACM0 does not change my Proto options (which is auto or qcm). Changing to Auto doesn’t resolve the issue either. If anything it makes it worst as it never actually connects (where the qcm connections, but I don’t get an IP).
I set the GUI to be Auto with cdc-wdm0 as the device, and modified the config as requested. Still does not connect (doesn’t appear to attempt like the qcm did). Below is the config from the network file:
At the time, no. I have booted it back up (so it has been offline since I changed the setting and last tested) and it did not make a difference. With the qmi settings, it still does not connect.
