hey all
I’ve just installed the latest beta for Beryl and I noticed two things:
the Fritzbox relay error is gone, I have internet now
when I power up the router, it takes at least 3-4 min to properly load and I’m able to connect to wifi and sometimes, I can connect but then the router drops me and I have to reconnect
point 2 is a new issue and I didn’t notice on previous firmware
If the router takes extram long to boot, check the LED status.
A normal boot process, the LED will go
Solid blue, indicating boot
Flashing blue, indicating connecting to the Internet
White, connected to the Internet
If you see the LED suddently flashes then go solid blue, it mean means it rebooted. In this case, check the power adapter you are using. Maybe change one.
I had this error when updating to the latest stable version but the beta has this changelog
2. Fixed MT1300 cannot relay Fritzbox's wifi.
so this one is definitely fixed
I don’t see the router rebooting, the process goes as you described…I counted the boot time, and it takes around 1 and a half minutes so I think it is fine, I was just overreacting since I swear in the previous version (3.203) was faster than that but this is definitely not a long time
