Beryl MT-1300 VPN management
I know the original Beryl MT-1300 is getting a bit left behind now which is understandable but may I ask if it's possible to improve the VPN management on the current firmware.
With the new firmware builds for the latest models we can view the clients list and see what devices are using a VPN tunnel by the VPN Icon indicator and we can also select a client to add/remove from the tunnel from the clients list. On the Beryl MT-1300 this isn't the case.
The reason I'm asking for better VPN client management is because I setup this device for relative that isn't tech minded. They don't know how to access a gui IP and view all the settings, instead I setup the glinet android app and show them how to toggle the VPN on / off but unfortunately there is no way via the app (for the MT-1300) to be able to see which clients are on the VPN and to add/remove the clients from the policy list, the user would need to login to the gui to perform those actions.
So with that being said, is it possible that we can at least have the function to add / remove clients to the VPN and see the VPN status indicator via the android app for the Beryl MT-1300
On the beryl mt-1300 we do not get this luxury.
Thank you for your suggestion.
We have forwarded your request to the product team, who will evaluate whether it can be supported in a future release.
Yes, the marvelous VPN implementation in 4.8 is what I really lust for in my Beryl and Mango. I'd dump a lot of other things for that; so happy to see it in the Mudi 750.
