Latest Snapshot Firmware 4.2.1 2023-04-09 17:42:04 (UTC-04:00)
SHA256: afe6237d0ca03b14960ad92ff2e1b3747399661523544fa267be8dab3c8d31fa
Router is connected and can access internet but LED is always slow flashing blue (indicating a issue). It appears MWAN3 is not working correctly. Restart of the router or services does not seem to change anything.
Log file:
GL-MT1300 MWAN issue 4-16-23.zip (14.5 KB)
I try that version it works okay in my environment. Did the previous version work?
It looks like your connection may not be stable based on the log. Could you share this debug information?
root@GL-MT1300:~# ethtool wan
Settings for wan:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 4
Transceiver: external
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
root@GL-MT1300:~#
The connection seems to be fine, I am using it to post, It will not stop flashing blue ( indicating a problem) but everthing seems to be working other than that
Previous version worked fine:
openwrt-mt1300-4.2.1-0330-1680127730
- SHA25670896f236b04e829650eae43d329d00823af76abb14060cb35bf42008ee0294b
BusyBox v1.35.0 (2022-10-14 22:44:41 UTC) built-in shell (ash)
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
|_____|| |||||___||| |____|
|| W I R E L E S S F R E E D O M
OpenWrt 22.03.2, r19803-9a599fee93
Settings for wan:
1000baseT/Full
1000baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 4
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Link detected: yes
root@GL-MT1300:~# 2023-04-09 17:42:04 (UTC-04:00)
went back to this one everything worked with no issue
Log right after revert:
Log after flashback 4-17-23.zip (16.3 KB)
Here is the log that ran for 9 days using this snapshot:
Logread 4-6-23 to 4-15-23.zip (24.1 KB)
This appears to be a bug in the snapshot 2023-04-09. I checked my tested version yesterday, it’s 2023-04-10, so this one should be fine.
And I found a changes about mwan3 here
