Beryl MT1300 - Wireguard unable to connect
Hi All
I was running version 3.x on my Mt1300 and upgraded to 4.3.11. I downloaded my Wireguard profile from ProtonVPN but am running into issues.
Everything runs fine until I enable the Wireguard VPN at which point it seems all internet traffic is blocked. Any ideas?
Below is what was copied from the VPN Log:
Wed Jun 5 16:21:49 2024 daemon.notice netifd: wgclient (29770): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Wed Jun 5 16:21:49 2024 daemon.notice netifd: wgclient (29770): [!] Section glblock option 'reload' is not supported by fw4
Wed Jun 5 16:21:49 2024 daemon.notice netifd: wgclient (29770): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Wed Jun 5 16:21:49 2024 daemon.notice netifd: wgclient (29770): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Wed Jun 5 16:21:49 2024 daemon.notice netifd: wgclient (29770): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Wed Jun 5 16:21:50 2024 user.notice mwan3[29769]: Execute ifdown event on interface wgclient (unknown)
Wed Jun 5 16:21:50 2024 daemon.notice netifd: wgclient (29770): DROP all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 match-set GL_MAC_BLOCK src
Wed Jun 5 16:21:51 2024 daemon.notice netifd: wgclient (29770): Failed to parse json data: unexpected character
Wed Jun 5 16:21:51 2024 daemon.notice netifd: wgclient (29770): uci: Entry not found
Wed Jun 5 16:21:51 2024 daemon.notice netifd: Network device 'wgclient' link is down
Wed Jun 5 16:21:52 2024 daemon.notice netifd: wgclient (29770): sh: 1: unknown operand
Wed Jun 5 16:21:52 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Wed Jun 5 16:21:53 2024 daemon.notice netifd: Interface 'wgclient' is now down
Wed Jun 5 16:21:53 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Wed Jun 5 16:21:54 2024 daemon.notice netifd: Network device 'wgclient' link is up
Wed Jun 5 16:21:54 2024 daemon.notice netifd: Interface 'wgclient' is now up
Wed Jun 5 16:21:56 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_3744 group_3062 group_6029 group_3566 group_38 peer_2001 CONFIG_cfg030f15_ports=
Wed Jun 5 16:21:56 2024 user.notice mwan3[30867]: Execute ifup event on interface wgclient (wgclient)
Wed Jun 5 16:21:56 2024 user.notice mwan3[30867]: Starting tracker on interface wgclient (wgclient)
Wed Jun 5 16:22:00 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
The syslog you attached is no problem, the wgclient interface has up and reload firewall rules.
Could you please share your wg profile with me and I try it at my GL router? kindly via PM.
Hi, I have tested at my side, it works ok.
Please check it again at your side, and let me know if it still has issue.
Thanks Bruce. I’ll give it a try. Maybe my firewall is blocking the traffic. If it is would you have any idea why the Beryl VPN would have issues when running Proton VPN on an iPad connected to the Beryl doesn’t have issues?
Please share the syslog regards the WG client running with Proton VPN of the Beryl.
At my side, it works well, while means that your account also includes your wg.conf are no problem, as well as your router is supposed to work ok, I think, as I did not have any other special settings.
