Hi everyone,
I’m experiencing an issue with my GL.iNet Beryl MT3000 router, and I’m hoping someone can help or has encountered a similar problem.
Setup:
GL.iNet Beryl MT3000 (latest firmware installed)
The only connected device is the TV connected via Ethernet to the Beryl MT3000 LAN port.
The Issue :
When I turn off the TV for a while and then turn it back on, the TV doesn’t reconnect to the internet. The Beryl MT3000 shows that no devices are connected via its lan, even though the TV is physically connected via Ethernet.
This is what I’ve Tried:
The same Ethernet cable and setup work perfectly with another router (also from GL.iNet) the Slate plus A1300 (lower end) here the TV remains visible in the connected clients even when turned off and back on.
I assigned a static IP to the TV to ensure that it doesn’t lose its IP address.
Confirmed that the Beryl MT3000 is running the latest firmware.
Performed a factory reset on the router and reconfigured it, but the issue persists.
With the Slate Plus A1300 router, the TV remains connected and visible in the client list even after being turned off and on.
When using the Beryl MT3000, after the TV is turned off, it disappears from the client list, and it doesn’t reconnect when turned back on, I initially thought a problem with the dhcp lease but the router is in its default settings, I also have other glinet and this router is the only one I am experiencing issues with.
Questions:
Has anyone else encountered a similar issue with the Beryl MT3000 or any other GL.iNet routers?
Are there any specific settings or workarounds that I might be missing?
Could this be a hardware defect, or is there something else I should try?
Any help or suggestions would be much appreciated!
Thanks in advance!
